PO440 code 2001 camaro 3.8L
PostPosted: Tue Oct 21, 2014 11:41 am    Post subject: PO440 code 2001 camaro 3.8L Reply with quote
SES light came on today on the way home from work, Went to vatozone and had them throw the code reader on it. Only thing that came up was the PO440 code.
Evidently its for EGR or EVAP system, a vac leak or something in the system or something not sealing properly. Did the obvious one and loosened and put the gas cap back on. Light still on.
I see the port on the intake for an EGR valve, but mine doesn't have one.
Aaron, I know you have experience with with the later Series II 3800's, any idea where I should start looking?
Does this thing even have a charcoal cannister or an equivilent to that? I couldn't find one.
Only thing I could really see this doing is affecting fuel mileage, but I'd like to get this fixed ASAP, as driving my F250 is a killer on gas. and its a 44 mile roundtrip to and from work.
Thanks in advance crew.
PostPosted: Tue Oct 21, 2014 4:49 pm    Post subject: Reply with quote
The charcoal can is back by the fuel tank.
I know I always preach against throwing parts at a problem, but I would consider buying a cheapo gas cap and see if that fixes it.
PostPosted: Wed Oct 22, 2014 9:46 am    Post subject: Reply with quote
It's got to see x amount of drive cycles passing the obd monitor to turn the light back off. Even if you fixed it best thing is to clear the codes. Otherwise drive three days and try again.
PostPosted: Wed Oct 22, 2014 5:38 pm    Post subject: Reply with quote
Check engine light is on with a trouble code P0440. DTC P0440
Average Reported Mileage:
121052
Tests/Procedures:
1. Activate the Evaporative Emission Control (EVAP) system vent and purge solenoids.
2. Check for the EVAP system to hold vacuum with either a gauge on the service port or by monitoring the Fuel Tank Pressure Sensor (FTPS) voltage.
3. Deactivate the EVAP purge solenoid, vacuum should hold and FTPS voltage should be higher than 1.5 volts.
Tech Tips:
FTPS voltage should be about 1.3 to 1.7 volts with the gas cap off. With vacuum on the system it should go up and hold. Inspect for leaks at the fuel cap, filler neck, fuel sender o-ring, evaporative canister, evaporative vent solenoid, evaporative purge solenoid, and evaporative hoses.
What fixed it for how many people?
53 - Fuel Filler Cap
24 - Evaporative Emissions (EVAP) Canister Vent Solenoid/Valve
20 - Evaporative Emissions (EVAP) Canister Purge Solenoid/Valve
13 - Evaporative Emission (EVAP) System Hose(s)/Line(s)
5 - Fuel Filler Neck
4 - Fuel Filler Cap, Fuel Filler Neck
3 - Evaporative Emission (EVAP) Canister
2 - Fuel Tank Pressure Sensor (FTPS)
2 - Evaporative Emissions (EVAP) Canister Purge Solenoid/Valve, Fuel Filler Cap
2 - Canister Vent (CV) Solenoid
2 - Fuel Cap Gasket
1 - Evaporative Emission (EVAP) Canister, Fuel Tank Pressure Sensor (FTPS)
1 - Evaporative Emission (EVAP) Canister, Evaporative Emission (EVAP) System Hose(s)/Line(s), Fuel Tank
1 - Evaporative Emission (EVAP) Canister, Evaporative Emissions (EVAP) Canister Vent Solenoid/Valve, Fuel Filler Cap, Fuel Filler Neck
1 - Evaporative Emissions (EVAP) Canister Purge Solenoid/Valve, Fuel Pump Module Assembly
1 - Canister Vent Filter, Evaporative Emissions (EVAP) Canister Vent Solenoid/Valve
1 - Fuel Pump Module Assembly
1 - Fuel Tank Sending Unit O-Ring
1 - Evaporative Emissions (EVAP) Canister Vent Solenoid/Valve, Fuel Filler Neck
1 - EVAP Canister Vent Hose
1 - Evaporative Emission (EVAP) System Hose(s)/Line(s), Evaporative Emissions (EVAP) Canister Purge Solenoid/Valve
1 - Evaporative Emissions (EVAP) Canister Purge Solenoid/Valve, Evaporative Emissions (EVAP) Canister Vent Solenoid/Valve
1 - Evaporative Emissions (EVAP) Canister Vent Solenoid/Valve, Fuel Filler Cap
PostPosted: Thu Oct 23, 2014 2:40 pm    Post subject: Reply with quote
Borrowed a friend's code reader and cleared the codes. light went off. More to follow in the next few days. as I drive it. (Mine just crossed 136K, last week) We'll see if the light pops back on over the weekend.
Paul, thanks dude.
If SES goes back on, Go key on, The first thing is to check FTPS with a multimeter?
Is this correct?
PostPosted: Sun Oct 26, 2014 7:21 pm    Post subject: Reply with quote
If it comes back, I'd put a cap on it, clear it and go.
