Posted: Wed Jun 11, 2014 6:36 pm Post subject: DIY Muffler |
So a few months ago I came across someone building their own muffler. Ive been occasionally hunting around for information on this. Wonder if anyone here has attempted this?
So the most basic and commonly made one is the "glass pack" style. Blow thru, holes inside, wrapped with fiberglass and then steel outer body.
More complicated, the baffled one where the airflow has to bounce n move around.
Ive been wondering if differently grades/styles of material change the sound since its all acoustics? What about changing from fiberglass to steel wool? Size of the holes? Location/pattern of holes. Angles of baffles.
Discuss. _________________ 2008 GMC Z71
Posted: Wed Jun 11, 2014 7:06 pm Post subject: |
A friend of mine built one for his BB 87 maro. Dual in dual out packed with stainless steel wool. He was attempting to make it a sleeper but it was still fairly loud. |
Posted: Wed Jun 11, 2014 8:15 pm Post subject: |
I built a muffler for my bmw (that I haven't mounted) and a resonator. Both were the "flow through" style. Expanded metal mesh rolled into a tube shape and shoved into a case that was packed with filler. The muffler I cut apart two other mufflers for materials so I used their filler. The resonator I actually used r19 fiberglass house insulation. I tested the insulation by holding my torch against it for about 5 minutes and it didn't do much so I figured it would be okay. _________________
Posted: Thu Jun 12, 2014 4:54 pm Post subject: |
I didn't think the steel wool would quiet it much, but I have seen a few postings about using it. Most use fiberglass, or a combo of both.
Did that expended metal come from inside the mufflers you cut apart, or a home depot find? Also how big were the holes? |
