Posted: Sat Dec 07, 2013 12:19 pm Post subject: help finding pass thru vss pulse generator |
I'm almost done with my L05 swap into my jimmy. But I cant get it to shift because I have the incorrect vss.
Since the speedo is cable driven, and my transfercase is cable driven. I need one of the pass thru pulse generator devices.
I originally got the Dakota digital one which is 8000ppm/ac wave. But found it to be incorrect pulse amount.
I then got painless 60117 which is 40000ppm, but must be dc because I cant get It to shift/test like I'm being told.
Now I just cant find what I need. Its either called 40pulse per rev, or 40000 pulse a mile. Then need it to create ac sine wave.
Has anyone seen a device with these specs? _________________ 2008 GMC Z71
MrMike98 Member
Posted: Sat Dec 07, 2013 3:25 pm Post subject: |
dakota digital SGI-5c calibration box-
this is the bomb...
u can input anything and get out anything else--ac-dc
AND
u can calibrate on the fly to get good speedo-etc
check it out.
M |
Posted: Sat Dec 07, 2013 3:34 pm Post subject: |
Yea, i'm afraid I will have to go to that, rather then the stock converter box. Was wanting to use as much oem stuff as possible. |
