popballz Member
Posted: Wed Dec 04, 2013 5:54 pm Post subject: Did i buy the wrong injectors? |
hey guys im working on my 1987 trans am. Well more like just spending money. I took my car into a garage today and he said the injectors that I installed are at least 15% too lean for my engine.
I installed "BOSCH DESIGN III 19 LB FUEL INJECTORS". These arrived with a ford logo on them. these right here
So are these the wrong injectors for a pretty stock 305 tpi? _________________ -Donald
Posted: Wed Dec 04, 2013 7:19 pm Post subject: |
19lb is correct for a 305TPI with the stock ECU calibration. _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed Dec 04, 2013 8:02 pm Post subject: |
Except those don't look like Bosch yellow-tops.
Need the specific part number off the injector. It will be on the side of the injector body and will be a zero followed by three sets of three digit numbers, like 0 280 XXX XXX. If it has a Ford part number on it (FXAE-XXXX) I can use that too.
Posted: Wed Dec 04, 2013 8:48 pm Post subject: |
You need to scan it and see what the blm is at. _________________ A redline a day keeps the carbon away! |
