rear gears setup question?
MrMike98
PostPosted: Mon Aug 05, 2013 4:37 pm    Post subject: rear gears setup question? Reply with quote
i am installing a new carrier(tru-trac-posi) into my existing housing (10 bolt)..
How do u makeup the initial shim pack for the carrier..
i know the shims need to be split between sides and adjusted by wear pattern.. i just dont know if the carrier needs to be preloaded or is it zero clearance? or is ther some "slop".01-.003"??
changing gears/carrier sounds easy on paper---
anyone have a bored out pinion bearing for setting wear patterns??
Mike
PostPosted: Mon Aug 05, 2013 4:55 pm    Post subject: Reply with quote
http://yukongear.com/Downloads/Manuals/Yukon_Installation_Instructions.pdf
