Project_1986_TA Member
Posted: Tue May 04, 2004 11:30 pm Post subject: 19lb Injectors |
| I have a used set of 19lb an hour injectors. They still work but should probably be cleaned. Not sure what brand they are, i'll look tomorrow. Make an offer. |
Gibby85 Member
Posted: Fri May 07, 2004 12:02 pm Post subject: |
| Gibby85 wrote: | | Isn't that the stock rating for TPI injectors? |
Yes Sir. |
Posted: Fri May 07, 2004 12:08 pm Post subject: |
| Dewey316 wrote: | | Gibby85 wrote: | | Isn't that the stock rating for TPI injectors? |
Yes Sir. |
Stock rating for 305 TPI injectors
350 TPI injectors are 22lbs |
