WTF IAC and TPS.... high idle for no reason
Goto page Previous  1, 2, 3
BluFbdy
PostPosted: Sun Oct 21, 2012 11:36 am    Post subject: Reply with quote
ok so i adjusted it down without grounding the aldl, brought my throttle plates almost totally closed and the idle down to 825 sitting in neutral warmed up, but my IAC steps would not go down, it went to 50 for a second there, im gonna try resetting the minimum air again and then attempting it one more time. if my idle is down im fine with it but id like to see the IAC acting properly
PostPosted: Sun Oct 21, 2012 2:48 pm    Post subject: Reply with quote
It may not really go that low with the settings in your tune though. If the idle is good and consistant, roll it for a few days and see how it goes.
BluFbdy
PostPosted: Sun Oct 21, 2012 4:21 pm    Post subject: Reply with quote
This is true lol ill let it go for a few days and see how it is, its not a performance motor by any means so as long as I'm not burning gas I'm fine with it
Page 3 of 3
