Sept PIR Gathering Headcount
Goto page Previous  1, 2
Post new topic   Reply to topic    Cascade Crew Forum Index -> Event Calendar
PostPosted: Thu Sep 13, 2007 9:36 pm    Post subject: Reply with quote
[quote="DBL_TKE"]
Quasi-Traction wrote:
DBL_TKE wrote:
I'll be there for sure, the track that is. Won't have time for pizza though, I have work from 5:30 to midnight.
I might have to have you tech me. I don't think I'll pass otherwise.. Sad
I thought you passed last time? No problem though.
Breather is caughing up a significant amount of oil I"ll try to clean up before saturday, plus the fuel line issue they gave me a hard time for last time.
I need to fix my shock mount before Saturday. I lost the bolt and bent the pirch on the axle somewhere on the K-falls gathering/cruise.
PostPosted: Thu Sep 13, 2007 9:38 pm    Post subject: Reply with quote
How the hell did you bend the bracket on the axle?!
PostPosted: Thu Sep 13, 2007 9:44 pm    Post subject: Reply with quote
I dunno....I did notice about halfway home I heard a high pitched "ping" sound and there was a loud rattling sound from there on home....
Its not bad on the axle, I think vice grips and a propane torch and a trip to the JY and hardware store should solve the problem.
I think I'll go for the "jam nut" effect and grab two from the hardware store this time.
PostPosted: Fri Sep 14, 2007 2:21 am    Post subject: Reply with quote
what is wrong with your fuel line? that may just be the most expensive part on the whole car! it is done ultra proffessional. what were they complaining about?
PostPosted: Fri Sep 14, 2007 9:24 am    Post subject: Reply with quote
He probably has too long of a run of rubber line.
PostPosted: Fri Sep 14, 2007 10:25 am    Post subject: Reply with quote
no thats what i am talking about. there is NO rubber line. chris and i went down to OFS and had a braided steel one made, it's all top nothch. braided steel from fuel pump to carb.
huh... from carb to tank though.... yeah, i bet there is rubber there.
PostPosted: Fri Sep 14, 2007 11:56 am    Post subject: Reply with quote
Yup yup 7 Inches too much to be exact. As well as the oil leak. The guy who teched me last time was kind of cool about it, but he made a point that he probably shouldn't have let me pass.
no thats what i am talking about. there is NO rubber line........braided steel from fuel pump to carb.
Where the hard lines come off the frame rail to the inlets for the fuel pump, there's rubber lines there.
PostPosted: Fri Sep 14, 2007 2:43 pm    Post subject: Reply with quote
maximum amount of allowed rubberized fuel line is 12" so how are you too short? or are you saying that you have 21" of rubber line?
PostPosted: Fri Sep 14, 2007 5:08 pm    Post subject: Reply with quote
I have about 20" of rubber line between the frame rail's hard line, to the pump. 10" on the inlet, 10" on the pressure return line.
PostPosted: Sat Sep 15, 2007 11:26 am    Post subject: Reply with quote
I see. Was there anyone from the crew at PIR last night? There was a black IROC there that ran 15's and a gray camaro that ran 13's and was very clean, had some meaty tires in the back too.
Post new topic   Reply to topic    Cascade Crew Forum Index -> Event Calendar All times are GMT - 8 Hours
Page 2 of 2
