9 bolt, 91-92 gfx, head porting, etc...
PostPosted: Tue Nov 29, 2005 6:24 pm    Post subject: Reply with quote
This is your friend.
PostPosted: Tue Nov 29, 2005 7:45 pm    Post subject: Reply with quote
yeah, a mop wouldent hurt.... Shocked
Sellmanb
PostPosted: Tue Nov 29, 2005 8:31 pm    Post subject: Reply with quote
yeah yeah. I just mopped the heck out of the garage too, but then I layed the rear end down there without the cover and the rest of the fluid went all over (you can see how it seeped out lol) So I put the cover on then.
Yep I'll be there at 11. Chris if you see this, let me know if you'll be there to check out the nose. I dont expect you to purchase it, but let me know so I'll know if I should be bringing it along or not.
PostPosted: Wed Nov 30, 2005 12:33 am    Post subject: Reply with quote
i mentioned i was going to snoop around a 4th gen and aa guy in my class mentioned that the rear seats from an 02 will match the 2002 cavalear (sp) seats i have up front. i am thinking about it..... Cool
PostPosted: Wed Nov 30, 2005 12:37 am    Post subject: Reply with quote
hey, when you get to the junkyard if i am not with my car (awsome black GTA) i am probably still in the yard, give me a ring. 971-645-9359. thanks
Sellmanb
PostPosted: Wed Nov 30, 2005 8:20 am    Post subject: Reply with quote
I'll do that after I scope your car out Wink
List has been updated with more items
In a couple more days ( at 12/2/05) these items go on TGO and the prices raise, let me know if you guys are interested in something so I dont post it over there.
PostPosted: Wed Nov 30, 2005 10:31 am    Post subject: Reply with quote
Post up a picture of that dash. I kinda like that swap idea...
Sellmanb
PostPosted: Wed Nov 30, 2005 12:46 pm    Post subject: Reply with quote
There's a picture of it in my car when I just got it mounted up.
Sellmanb
PostPosted: Wed Nov 30, 2005 1:21 pm    Post subject: Reply with quote
Tony, I just realized that you didnt get the other rotor. I know you said that you were thinking about going with bigger brakes and rotors in the back, so let me know if you end up wanting this other rotor or not. Worse case scenario I'll bring it to dyno for yah. Sweet ride by the way Wink
PostPosted: Wed Nov 30, 2005 1:59 pm    Post subject: Reply with quote
I want. Shocked
How'd you mount it up? Can you wait till my next payday? I just dumped almost all my spare cash on paying off the nasty credit cards (right before the holidays in whic i'll probably end up racking up a bit again Mad )
If it's a first come, first serve thing I can dig it.
Sellmanb
PostPosted: Wed Nov 30, 2005 2:09 pm    Post subject: Reply with quote
Iansane, I have no problem holding it for you. Just let me know when and where you'd like to meet up.
Just to make sure you know what you're getting.
It doesnt have the radio bezel trim (a small piece that goes around the radio and HVAC area), and it needs the dash pad. But for the price I'm selling it for (check eBay to see going rates) you should be able to get those pieces for way less than the going rate still.
There were no scratches or cigarette burns that I know about, it is grey in color (I had planned to spray dye it ebony).
Oh, and the prior owner had put a radar detector on the dash, and it still has two dabs of hot glue on it.
I have more pictures of how it mounts, let me find them. But for the most part you'll only have to drill out one hole (the other 2 or 3 are just right), and then just bend back your dash frames on the side.
Sellmanb
PostPosted: Wed Nov 30, 2005 2:17 pm    Post subject: Reply with quote
There's a picture of how it looks without the dash in there (You can see the center console I have for sale as well lol)
You can see where I cut the bracket at, I then bent it back.[/img]
PostPosted: Wed Nov 30, 2005 8:26 pm    Post subject: Reply with quote
i think i am going to go with bigger rotors on the rear, so don't worry about getting that one to me. but don't throw it away. if i have not got anything done by dynoday i'll get it then.
also, you mentioned to me you were not using the plate on the center console, in the picture it looks like it fits Confused do you still have it? if so i'll give you $65 for the complete console. (in which case i can get the rotor from you when i get the console)
Sellmanb
PostPosted: Wed Nov 30, 2005 8:32 pm    Post subject: Reply with quote
Tony, the whole center console goes great together! Until you put the dash in! LOL. The whole shifter assembly needs moved back, which in turn requires a different length shifter cable, not to mention that the 3rd gen gears are closer together than the 4th gens, so when you go from OD to D, the indicator is like in between OD and D, not solidly on it, so you'd need a 4th gen shifter assembly as well. otherwise, you'll need a manual shift plate for the easy way out.
edit:
here you can see how it doesnt line up correctly with the shift plate on.
PostPosted: Wed Nov 30, 2005 8:40 pm    Post subject: Reply with quote
i could care less if it lines up with the letters Laughing ... if i had a stick one there would be NO letters. i pretty much have the pattern memorised. but you still have the 4th gen plate right? i may end up snagging the shifter out of the 4th gen @ tigardupullit (might do ebrake leaver too, and all associated cables)
Sellmanb
PostPosted: Wed Nov 30, 2005 8:44 pm    Post subject: Reply with quote
If you want the 4th gen e brake I have one I'll throw in for free that came from the same vehicle as the center console. Yeah I still have the plate sitting in the trunk of my camaro lol.
PostPosted: Wed Nov 30, 2005 10:50 pm    Post subject: Reply with quote
cool i'll take it! do you have the cables and stuff too? they are verry different from thirdgen ones. the 4thgen ones do all the adjustment at the leaver, no crawling under the car with wrenches.... Get down and Boogie! if not no biggie, i'll just go back and rob that 4th gen blind!
Sellmanb
PostPosted: Thu Dec 01, 2005 9:36 am    Post subject: Reply with quote
nope I dont have the cables n stuff, but I dont think they would charge you for the cables (bring deep pockets) lol.
If you want to do Iansane a favor while you're out there, could you take the pigtail from the instrument cluster from that 4th gen out there ? It's the thing that connects to the gauges, just cut all the wires about 3 or 4 inches from where they connect in. He'll need one to get all of his wires connected for speedo, temp, oil, gas, etc.
If not, that's cool, I can go out there when I get a chance and pull one.
PostPosted: Thu Dec 01, 2005 12:06 pm    Post subject: Reply with quote
cut stuff. yeah, i can do that. i think i'll head out there on satarday.
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Sun Mar 26, 2006 12:02 pm    Post subject: Reply with quote
still go tthis stuff and how much???
1 "most" set of 91-92 ground effects (Camaro)
These are all light blue in color. They include the front chin spoiler and the rocker panels (on door and below door, both sides).
Looking to get 90 OBO
I have the nose/front bumper cover and a headlight assembly from the 91 Camaro (black in color) that I got the ground effects off of. They're still attached at the moment.
Hoping for 45 OBO
Cadillac of Bellevue
Retail parts sales
vee-six
Page 2 of 3
