tbi to carb help
Goto page Previous  1, 2
PostPosted: Mon May 12, 2014 5:07 pm    Post subject: Reply with quote
That would make it hard to bolt a mechanical pump up then... maybe get a big drill and some JB weld. No problem.
PostPosted: Mon May 12, 2014 6:31 pm    Post subject: Reply with quote
Alphius wrote:
I bolted a manual fuel pump up to an '87 TPI 1-piece RMS block with the stock cam and it worked fine. Maybe they got rid of the fuel pump lobe by '91 though. Just wanted to prove Paul wrong. Laughing
I forget what year the block is, but we put a mechanical pump on the L03 in James' second gen.
PostPosted: Mon May 12, 2014 6:44 pm    Post subject: Reply with quote
My 85 305 tpi block had the provision. Two piece rear. My 87 305 tpi didnt.
PostPosted: Mon May 12, 2014 7:21 pm    Post subject: Reply with quote
Weird. Must have been one of those things that GM was not consistent on over the years. My '87 305TPI engine definitely worked fine with a manual fuel pump. It was in an '87 T/A with a 700R4. Center bolt valve covers, roller cam, 1-piece RMS. Peanut cam. I stole the TPI off of it and put a Q-Jet on to give to my brother. The engine stamp matched the VIN on the car.
PostPosted: Mon May 12, 2014 7:23 pm    Post subject: Reply with quote
I thought I remembered the peanut cam not having the lobe. Weird. Gm so consistently inconsistent.
PostPosted: Mon May 12, 2014 7:44 pm    Post subject: Reply with quote
My LG4 has the roller cam and a factory manual pump. Odd combo. I've seen some blocks with the fuel pump boss and no pump rod hole. I've also seen some blocks without even the fuel pump boss. So I guess you could have just about anything.
91camaro_rs
PostPosted: Tue May 13, 2014 6:52 am    Post subject: Reply with quote
It should have hole for a mech pump its a crate motor. Not factory 91. He wants to keep the electric pump idk why but its not my choice lol
PostPosted: Tue May 13, 2014 12:49 pm    Post subject: Reply with quote
I'd keep it. It works. Its in tank. I've seen guys suck through the original pump with a mechanical but you're just asking for problems not putting in a carb pickup.
Wtf get rid of TBI anyway? Throw a single plane intake on it and you're a fuel injected carb with better everything.
PostPosted: Tue May 13, 2014 1:33 pm    Post subject: Reply with quote
Word...and I may have the right manifold for sale at some point this summer....
single plane + TBI is a pretty solid combo. None of the TBI motors will make power with their peanut cam and swirl-port heads.
PostPosted: Tue May 13, 2014 1:50 pm    Post subject: Reply with quote
With everything being gasahol I'd keep the in-tank pump as well. Avoid problems like this one with a fairly new Edelbrock pump that don't seem to bother in-tank pumps.
Also this. This forever. Yup yup
Page 2 of 2
