Posted: Sun Feb 22, 2004 12:54 pm Post subject: Next project... |
Ported, polished, 3 angle, milled down guides, postive seals, screw in studs, z28 springs, rotators removed, and surfaces milled 0.010.. l98s! New covers to match. Hopefully the truck wont be disappointing next time. |
Posted: Sun Feb 22, 2004 12:56 pm Post subject: |
Nice work B. That should wake her up a bit.
Posted: Sun Feb 22, 2004 1:01 pm Post subject: |
Forgot 1.6 comp rollers..
Heres a not so good, too close to focus pic of the original bowls.. lots of work done there.
Posted: Sun Feb 22, 2004 4:40 pm Post subject: |
| Wow, in the bowls, you want to cut down the area where the valve slides through? |
Posted: Sun Feb 22, 2004 6:12 pm Post subject: |
| The guide is just narrowed, rounded, and smoothed its still the same height. |
Posted: Sun Feb 22, 2004 8:58 pm Post subject: |
So which part is the valve seat? Do valve seats come out?
Wait, what, RED? Just cause they came off of mikes car doesn't mean they have to be RED  |
Roshambo Member
Joined: 08 Jan 2004 Posts: 280 Location: Sacramento, CA
Posted: Sun Feb 22, 2004 11:39 pm Post subject: |
Lookin good Brandon... that should register a few ponies on the ol' butt dyno.
-Joe |
TecherB Princess B
Joined: 14 Jan 2004 Posts: 390 Location: Some place between gresham and portland
Posted: Mon Feb 23, 2004 7:08 am Post subject: |
| looks good B Hopefully the time and energy you have put in to it is worth it. |
Posted: Mon Feb 23, 2004 7:23 pm Post subject: |
HOPEFULLY we can get his BUTT dyno out to the track!  |
Posted: Mon Feb 23, 2004 7:26 pm Post subject: |
Seats are still there Paul. and no they dont come out. Actually this is the first set of modern heads i've done for myself. So its the first set I havent had to install hardened exhaust seats in. And thats not RED! That be chevy orange for you people who are too young to remember what color real motors were painted.  |
Posted: Mon Feb 23, 2004 7:27 pm Post subject: |
| I was looking at my 416s today, I'd be afraid of taking too much off the intake ports before it would grind through the metal! |
Posted: Mon Feb 23, 2004 7:36 pm Post subject: |
That looks good Brandon, gonna have to put the holley back on it now though.
BTW, WTF is up with the degree wheel, when I installed my cam last spring you said that I didn't need to degree it. Me thinks you in cahouts with the Red guys.  |
Posted: Mon Feb 23, 2004 8:12 pm Post subject: |
| I've never degreed one Rodney. This will be my first, and i'm just checkin it. Paul and I have the same cam, only mines on a 110 and his is 112? His peaked on the dyno @ 5600.. My motor peaked at 4400?? Should be higher. So I'm wondering if my cams too far advanced. |
Posted: Mon Feb 23, 2004 9:01 pm Post subject: |
I am gonna get a degree wheel too. Unless Harold says other wise  |
Posted: Mon Feb 23, 2004 10:23 pm Post subject: |
Ok B, I am set for this weekend.
Paully, I need to get the dial indicator back sometime this week.
Thanks!
Posted: Sun Feb 29, 2004 12:19 pm Post subject: |
Well project missing power is complete! Almost... Anyway, Mr Schultz and I spent a long day yesterday tearing apart the trucks motor and swappin on the new heads, degreeing the cam, and puttin on some 1.6 comp rollers. Finished about 9 PM. Noticeably different, truck continues to pull on up in the rpm's now, and seems to require less pedal for cruising. Seems very much smoother to me now, the vibration i've been fighting for years wasnt there last night. A weeks worth of driving should prove if thats coincidence or not though.
BTW Mike, just got down re-reading the directions on degreeing the cam. We were supposed to add the 2 values together then divide by 2, instead of subtracting. 215+3=218 / 2 = 109.. So the cam is in 7 degrees advanced instead of 4. That is part of why it peaked at 4400 and had so much torque way down low on the dyno. Here's the other part. Since the 215* and 3* measurements were made at 0.050 lift at the lifter, the difference between the 2 should be 0.050 duration of the intake lobe. 212* right? Well, that # would be perfect if this was an XE256 cam!!! Which it is not!!!! The XE262 cam should be 218*!! If the measurement is correct that means i've got the same cam in both vehicles. But since this is a 350 instead of the 327 it'll actually act smaller!! Since the 327 peaked at 5250, that would totally explain the 350 peaking at 4400!!!(can't put too many exclamations!) I'm kinda pissed. I'm thinking that comp misboxed my cam. And since I didnt degree it, I never caught it till now.
Well, i'm debating puttin the holley back on now too, Though the edlbrock always runs good, i'm totally missing the throttle response(and the instant burnouts) the holley had. At least its an easy swap.
You guys thought the cloud of carbon at the dyno was bad?! You should see the buildup on my pistons! No wonder i've been having a dieseling problem. Huge thick layer of oil carbon built up. Appears to have been making it past my guide seals. We'll see if these positive seals clear up my oil consumption! Once we had the truck running i gave it about 3 cups of water induced orally (via drippin it in the carb). Hopefully that loosed up some of the garbage. Tomorrow, i'll pick up a couple can's of seafoam and see if I can FOG out Skamokawa.
Guess I oughta go do something. Pics of the finished project forthcoming. |
Posted: Sun Feb 29, 2004 1:07 pm Post subject: |
hehe - never poured water into an engine on purpose. Good project but sucks about the cam. The mesquite bar-b-qued rib-eyes were the highlight.
mmmmmmMMEEAat.
: burps mesquite smoke :
Thanks again Chef-Boyar-B!
Roshambo Member
Posted: Sun Feb 29, 2004 1:24 pm Post subject: |
Sounds like fun Brandon, sucks about the old cam though...
You should get pics of "Operation Smoke Out"...
-Joe |
Posted: Sun Feb 29, 2004 2:30 pm Post subject: |
So here's a pic of the old camelhumps and edlebrock covers. Both are 1964 vintage.
And this ones the completed motor.
Notice, as of 1/2 hour ago, there lives a holley under that air cleaner again. Back to instant burnouts and 2nd gear kickouts! As much as I hate em the holley definately puts down more power/torque then the edlebrock does, even tuned. Now if the power valve will hold up.
Couple of notes on the holley, I was having trouble with the throttle sticking. Turns out that the holes in the base gasket that came with my rebuild kit were probably almost 1/8" too small. This made a 1/16" ring sticking into the carb barrells which the throttle plates rubbed against. Nothing a razor blade can't fix, but something to watch for when you rebuild a carb. Also had to tack weld the throttle lever to the shaft, was starting to come loose a bit. |
Posted: Sun Feb 29, 2004 5:29 pm Post subject: |
I'll have a 262 available shortly
Glad you found some of the power... but with the 256 cam, is the cam in your engine STILL too far advanced making it seem yet ANOTHER step smaller? |
