Posted: Tue Jul 19, 2011 7:12 pm Post subject: Injector flow calculation |
Since getting information from this builder and his third party vendors, I decided to take my injectors out to have them flow tested. they are a pair of 5235206*ACR as stamped on the top of the injector body, which by my best guess are 61 lb/hr.
When I picked them up today, I looked at the data sheet to find they were tested at 20psi and had a flow rate of 104 (I assume that is lb/hr). For tuning, since I don't have the AFPR yet, nor a pump to support that pressure, how do I find out what the flow is at 13psi? _________________ 92 Camaro
Posted: Tue Jul 19, 2011 7:35 pm Post subject: |
| Do they have any other data points so you can extrapolate a curve? |
Posted: Tue Jul 19, 2011 7:50 pm Post subject: |
Not much of a data sheet. Just flow rates before and after cleaning and pressure setting for testing.
I did find one of RBob's formulas and a couple of other online flow calculators which seem to agree with each other. Seems that if indeed I am at 104 lb/hr @ 20psi, then at 13psi, the new flow rate might be 84 lb/hr.
http://www.csgnetwork.com/fiflowcalc.html
The engine builder said his TBI and carb guy rates the TBI at 700 cfm.
Also, plugging 84 lb/hr @ 13psi into the EBL utility program, those numbers support about 317 HP which is about what Paul Anderson (builder) said the motor could make. I'm still skeptical. |
Posted: Thu Jul 21, 2011 3:52 pm Post subject: |
| Well, that 104 number is cc per cycle, but I couldn't get how long the cycle was from the machine shop guy on the phone. I'll just go with the stock 5.7L 61lb/hr size and go from there. I can always get larger injectors later, assuming they'll fit the injector pod. |
Posted: Sun Jul 31, 2011 11:11 am Post subject: |
Why would they measure it in cc/cycle? Shouldn't it be cc/min? That would mean you would only have less than 10 lb/hr, which doesn't make sense at all. What did they do? I'd be a little miffed if I payed a company to do this service and they couldn't tell me what units they were measuring. _________________ E30
Posted: Sun Jul 31, 2011 11:47 am Post subject: |
I wasn't really satisfied to hear what the numbers meant and that there wasn't a way for me to convert them to a value I could use.
For now, I'm going with the standard 5.7L 61lb/hr @ 13 psi, the motor idles well with that and will rev smoothly and easily up to 3000 and this will have to do until I get a new fuel pump and adjustable regulator. I've also found a place where I can get the injector pod assembly with a pair of 454 80lb/hr injectors already installed for about $130. |
