		| Author | Message |
		| QwkTrip 11sec Club
 1989  Pontiac  Firebird
				|  Posted: Thu Jun 30, 2011 7:21 pm    Post subject: Okay, I give up.  Where is it? |   |
				| I need an exploded view of an LS1 engine with every last little bolt, washer, and part shown WITH PART NUMBERS.  Anybody run across this before?
 I found an exploded view but it just says "Bolt".  Ya, duh.  I can see that.
		| Back to top |  |
		| iansane Member
 1991  Pontiac  Trans Am
				|  Posted: Thu Jun 30, 2011 8:35 pm    Post subject: |   |
				| Make friends with a GM counter jockey. _________________
		| Back to top |  |
		| DBL_TKE Member
 1991  Chevrolet  Camaro Z/28
				|  Posted: Fri Jul 01, 2011 6:55 am    Post subject: |   |
				| Even then the sizes aren't always specified. _________________
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Fri Jul 01, 2011 8:57 am    Post subject: |   |
				| Perhaps I am missing something here, but why not just take a measurement for length and thread pitch, and buy a replacement bolt? Who cares what GM used from the factory. You think my old Ford stuff runs all the original FoMoCo bolts from 1963?  |  |
		| Back to top |  |
		| QwkTrip 11sec Club
				|  Posted: Fri Jul 01, 2011 11:26 am    Post subject: |   |
				| Not all bolts are equal.  I need to have a reference.
 If you didn't drive a Ford then the bolts wouldn't be falling out and missing in the first place.
		| Back to top |  |
		| 91RSVert Member
 1991  Chevrolet  Camaro RS
				|  Posted: Fri Jul 01, 2011 12:16 pm    Post subject: |   |
				|  	  | QwkTrip wrote: |  	  | If you didn't drive a Ford then the bolts wouldn't be falling out and missing in the first place. |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Fri Jul 01, 2011 2:45 pm    Post subject: |   |
				|  	  | QwkTrip wrote: |  	  | Not all bolts are equal. |
 Buy the correct grade of bolt based on what you think the load on it will be. Not rocket science here.
		| Back to top |  |
				|  Posted: Fri Jul 01, 2011 3:41 pm    Post subject: |   |
				| Only things like mains, rods, oil pump, heads, etc are important. Any external bolt can be just able anything. _________________
		| Back to top |  |
		| QwkTrip 11sec Club
				|  Posted: Fri Jul 01, 2011 3:43 pm    Post subject: |   |
				| I might have to do that.  Still would like to see if I can find a full parts list. |  |
		| Back to top |  |
		| QwkTrip 11sec Club
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Fri Jul 01, 2011 3:50 pm    Post subject: |   |
				|  	  | Twilightoptics wrote: |  	  | Only things like mains, rods, oil pump, heads, etc are important. Any external bolt can be just able anything. |
  For stuff like that, ARP. Otherwise, Tacoma Screw.  |  |
		| Back to top |  |
				|  Posted: Fri Jul 01, 2011 4:48 pm    Post subject: |   |
				|  	  | aaron_sK wrote: |  	  |  	  | Twilightoptics wrote: |  	  | Only things like mains, rods, oil pump, heads, etc are important. Any external bolt can be just able anything. |
 Only if he wants to get the mains line bored and rods re-sized...
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Fri Jul 01, 2011 5:00 pm    Post subject: |   |
				| I think nearly every bolt in an LS style motor is torque to yield. They may all need to be replaced.. and with the proper bolts. |  |
		| Back to top |  |
		| QwkTrip 11sec Club
				|  Posted: Fri Jul 01, 2011 5:31 pm    Post subject: |   |
				|  	  | iansane wrote: |  	  | Make friends with a GM counter jockey. |
 Not possible.  He's going to figure out really quick he's just a tool and I'm not paying their prices.
		| Back to top |  |
		| iansane Member
				|  Posted: Fri Jul 01, 2011 9:07 pm    Post subject: |   |
				|  	  | QwkTrip wrote: |  	  |  	  | iansane wrote: |  	  | Make friends with a GM counter jockey. |
 Meh, I was happy to provide specs and part numbers to guys wanting to shop at gmpartsdirect or really anywhere else. But then again I just liked to find random oddball stuff. I'm a car guy, not a parts guy.
  	  | DBL_TKE wrote: |  	  | Even then the sizes aren't always specified. |
 They may not be specific along with the corresponding parts around it but a good counterman can find the thread pitch/length/grade and part number for I'd say 99% of all bolts on a car. It's a matter of how hard they're willing to try.
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Fri Jul 01, 2011 9:11 pm    Post subject: |   |
				|  	  | chevymad wrote: |  	  | I think nearly every bolt in an LS style motor is torque to yield. They may all need to be replaced.. and with the proper bolts. |
 Lots of bolts in newer Chevy motors are TTY. Hell, the rocker bolts on the 3800 are. Figure that one out.
  Nothing's getting replaced with new TTY bolts, that's for sure. |  |
		| Back to top |  |
		| QwkTrip 11sec Club
				|  Posted: Sat Jul 02, 2011 6:12 am    Post subject: |   |
				|  	  | aaron_sK wrote: |  	  | Figure that one out.  |
 Well, isn't that exactly the point?  Somebody did figure out a reason.  When a seemingly odd design pops up (like TTY rocker bolts) it is almost always because it is the solution to a problem, whether in the design and function or to improve quality and process in manufacture.
 In my job I have to solve a lot of problems.  Almost every problem I have seen is related to bolts, screws, seals, and vibration.  Millions and millions of dollars worth of problems.  If you ask me, it really is rocket science.
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sat Jul 02, 2011 7:35 am    Post subject: |   |
				| More clamping force with a cheaper bolt.
 You're an engineer Jon. You know the "design and function" thing is a line for the salesmen. These "problems" are caused by bean counters far more than they are caused by actual physical issues.
 Obviously the fact is that I can order reusable rocker bolts from Comp Cams shows that it's not an issue of tensile strength needed, it's the fact that Comp charges $20 for a set of 12, and GM Parts Direct charges $3.75 for the same set in factory TTY. ARP wants $80 for a head stud kit, GM wants $30 for TTY head bolts.
 It was a decision made by GM engineers who figured that the number of times that the parts held down by TTY fasteners would need to be replaced under warranty (and thus require GM to pay for new fasteners) would be more than offset by a reduction in manufacturing costs. So 100K miles down the road when you or I get the car we have to muck around with this stupid BS while GM sits on a pile of cash.
 Now go look an on old 80's Oldsmobile with one of those god-forsaken GM diesels in it and you'll see an engine where the TTY bolts are absolutely a necessity due to the low number of head bolts used in a high-pressure application.
		| Back to top |  |
		| QwkTrip 11sec Club
				|  Posted: Sat Jul 02, 2011 9:23 am    Post subject: |   |
				| You have a dark and jaded view of engineering.  You have an absolutely correct view of aftermarket parts sales.
 In my experience most problems are the result of poor design or manufacturing quality.  Cost is a constraint that can be challenging.  I've had a manager say I can't use an awesome product because of cost.  I've never had a manager say I have to use a crummy product.  A good engineer has to be much more than a technical expert.  They have to know how to sell an idea and make a convincing story that is meaningful to a manager.  Many engineers have such a wide role of responsibilities that they are like a micro-business within the company.  In my case I am responsible for approximately $120,000,000 per year.
 I've never met this person who is referred to as the "Bean Counter."  Engineering managers make all the decisions while keeping in mind profitability.  At the end of the day it is a business -- and I want a pay check too.
		| Back to top |  |
		| blue89 Member
 1986  Chevrolet  Camaro RS
				|  Posted: Sat Jul 02, 2011 12:57 pm    Post subject: |   |
				| I would tend to agree with you but there is the problem of having a sales driven engineering manager. I've been told to use crappy product before when I knew there was something better. Boss said I had to, so I did. For the most part though, the boss will do whatever I say is the best decision, so that's nice. |  |
		| Back to top |  |
