jchaussee Member
Posted: Wed May 11, 2011 7:25 am Post subject: detent cable bracket |
| I need a detent cable bracket. I went to carbnation and they said the only way to get the correct one would be out of another camaro |
Posted: Wed May 11, 2011 10:27 am Post subject: |
Same as throttle cable bracket with cruise and TV cable holes? Would it be the same as the TBI cars use? If so, there are a couple in the yard at Poulsbo. I need mine to modify the Edelbrock bracket I have to accept the cruise cable. _________________ 92 Camaro
jchaussee Member
Posted: Wed May 11, 2011 10:35 am Post subject: |
| I am not sure it it is the same. I have a bracket on it now but my detent cable doesn't fit in its " hole" and from its hole to the place where it mounts on carb it goes towards the passenger side about a half inch. My throttle cable though is in a straight line and fits good. |
Posted: Wed May 11, 2011 11:37 am Post subject: |
| I'll get a pic of mine (off the car now) when I get home and see if it's the same as what you need. |
jchaussee Member
Posted: Wed May 11, 2011 11:45 am Post subject: |
| Cool. Thanls. I also posted on TGO. Also if you get a chance look at the subbox on craiglsist and tell me if you think its a good deal. I know you like your sub boxes |
Posted: Wed May 11, 2011 5:11 pm Post subject: |
Here ya go. This one works for TBI, may work for carb also, depending on linkage. Bottom hole is for throttle, top for cruise and the middle I assume is for the TV cable, empty for my application. This one was secured to one of the coil mounting bolts and the angled tab secured to the furthest back intake manifold bolt. I think there are one or two of these in the Poulsbo yard, I know of one for sure, but I need this one.
kurfbird Member
Posted: Wed May 11, 2011 5:18 pm Post subject: Dentent cable bracket carburator |
I ahve a detent cable bracket from a 85 z28 carburator car _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Wed May 11, 2011 5:43 pm Post subject: |
| kurfbird wrote: | | I ahve a detent cable bracket from a 85 z28 carburator car |
Bruce to the rescue
| jchaussee wrote: | | Also if you get a chance look at the subbox on craiglsist and tell me if you think its a good deal. I know you like your sub boxes |
If it's the one with the fire extinguisher recessed into the top, looks like a good deal to me. Even if it comes without the speakers, $80 isn't a bad price for a 3rd gen specific box. |
jchaussee Member
Posted: Wed May 11, 2011 6:14 pm Post subject: |
| I knew bruce would have one. I was hoping to save up some money to get those heads before I came north to see ya. And ya. I may see about gettting that box. I don't have speakers yet, but I don't think I could build it for less |
