Firebird "tool tray" necessary?
PostPosted: Sun Apr 03, 2011 1:38 pm    Post subject: Firebird "tool tray" necessary? Reply with quote
Is the tool tray in front of the radiator a structural member on the Firebirds?
MrMike98
PostPosted: Sun Apr 03, 2011 1:40 pm    Post subject: Reply with quote
Yes it holds and supports the front bumper cover.
Mike
PostPosted: Sun Apr 03, 2011 1:42 pm    Post subject: Reply with quote
Looking for a way to get a lot of air into my LS engine without sucking water and debris off the front tire.
PostPosted: Sun Apr 03, 2011 7:01 pm    Post subject: Reply with quote
Without that cover air will lift up the front of the hood immensely. I take it you're not a fan of hole-sawing one of the battery trays?
Even if the tray wasn't needed you wouldn't get much air over the top of the core support. Look how thin the camaro intakes are and then remember that 'birds hoods are even lower.
PostPosted: Sun Apr 03, 2011 7:42 pm    Post subject: Reply with quote
Going through the battery tray is one of the options. My supercharged '94 Vette had an air cleaner near the ground in front of the tire and I was constantly cleaning the thing.
PostPosted: Sun Apr 03, 2011 8:11 pm    Post subject: Reply with quote
I'm sure it is, but as long as all the under body work is intact the side pieces for the airdam will block water from splashing straight up onto a filter there.
PostPosted: Mon Apr 04, 2011 3:47 am    Post subject: Reply with quote
The 'Vette had a completely housed wheel well. It was just being close to the ground that was the problem. Very dusty place. A little elevation makes a lot of difference.
PostPosted: Mon Apr 04, 2011 6:57 pm    Post subject: Reply with quote
If you get rid of the tool tray where is your mechanic gonna set his wrenches while he finishes your car?
3rd degree burnage Twisted Evil
PostPosted: Tue Apr 05, 2011 3:02 am    Post subject: Reply with quote
the tool tray supports and allows you to adjust the bumper to the hood. the metal bumper is right there though if you wanted to fab a frame off it or something. i was going to use the fog light holes for air but idk what gfx u have.
i ran it without a tool tray for awhile with no problems but that is deffantly something to look into.
-Donald
PostPosted: Tue Apr 05, 2011 6:22 am    Post subject: Reply with quote
where would the hood latch too? Confused
PostPosted: Tue Apr 05, 2011 4:17 pm    Post subject: Reply with quote
Heck, I need a mechanic right now for the 4th gen. Just can't get it to idle right. Shrug
