fiveoformula Member
Posted: Thu Mar 24, 2011 4:22 pm Post subject: 305 hop-up |
I have just aquired some 062 casting vortec heads I want to put them on my current TBI 305 and get a cam that works well with them. I have a few questions that im having trouble finding answers to.
I know I'll need a vortec specific manifold, And I know any carb intake with a TBI adapter will work BUT, will a single plane or dual plane work better?
Also I've read that compression will go down to much unless I get these heads milled down, but I haven't been able to find out how much they need to be milled for good use on a 305.
And of course the cam, this will still be my daily driver once it's all done, I was thinking of one with specs like this one:
http://www.summitracing.com/parts/LUN-501A1LUN/
Anything I should be worried about? _________________
'88 FORMULA |
Posted: Thu Mar 24, 2011 4:37 pm Post subject: |
Talk to Dewey. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
fiveoformula Member
Posted: Thu Mar 24, 2011 4:55 pm Post subject: |
I wanna talk to everybody lol. But that cam is pretty much just like dewey's. figured that it worked great for his combo. |
Posted: Thu Mar 24, 2011 5:18 pm Post subject: |
Single plane with TBI will net more top end. Not MUCH sacrifice on the low end.
Find a TBI specific Vortec manifold IMHO. Otherwise hood clearance might be a premium. _________________ A redline a day keeps the carbon away! |
Posted: Thu Mar 24, 2011 5:22 pm Post subject: |
I think that is the exact same cam I have, at at least VERY close. Since my cam designer worked for Lunati for a while.
You know the numbers my car makes, if you want a little more there are several good cams that work, I think the 210-215* intake range should go very well in your car. For a bit much agressive grind than mine, this one looks pretty nice.
http://www.summitracing.com/parts/LUN-60110/
Just make sure your Votecs are machined to take the extra lift, and get the right springs. |
fiveoformula Member
Posted: Thu Mar 24, 2011 5:31 pm Post subject: |
That is another thing, how do I choose the right springs? |
Posted: Thu Mar 24, 2011 5:49 pm Post subject: |
There should be a spring recommendation with whatever cam you choose. Make sure they fit your heads. If you do choose a lunati cam however.. I have NOT had good luck with their springs. I've broken 7 or 8 of them in my truck over a 3 year period. Last year I bought a set of summit branded springs that are spec'd similarly. So far so good. Since summit owns trick flow.. i think they're probably trickflow springs(which will actually be made by someone else yet LOL) |
Posted: Thu Mar 24, 2011 6:49 pm Post subject: |
I know a few vans had vortecs and TBI. Start looking in the junkyards. |
Posted: Thu Mar 24, 2011 6:58 pm Post subject: |
91RSVert wrote: | I know a few vans had vortecs and TBI. Start looking in the junkyards. |
Sorry.. I hit quote but with my mad moderator powers it edited your post! LOL
Anyway.
Vortec motors were CPI, as far as I know all tbi motors got the swirl port heads under them. |
fiveoformula Member
Posted: Thu Mar 24, 2011 8:13 pm Post subject: |
The intake that GMPP makes is $400 bucks
I may have to run a carb intake to cut cost... |
Posted: Thu Mar 24, 2011 8:46 pm Post subject: |
I have a similar intake going on my new motor. It's a Vortec to match the heads and made for TBI, and costs a little more. _________________ 92 Camaro
fiveoformula Member
Posted: Thu Mar 24, 2011 9:07 pm Post subject: |
Dang, what kind is that Al? the only one on Summit is that GMPP. |
Posted: Thu Mar 24, 2011 9:14 pm Post subject: |
Don't know the brand offhand, the builder selected it for me specifically for the heads and throttle body. |
Posted: Thu Mar 24, 2011 9:40 pm Post subject: |
I would try to find a low-rise single plane intake for vortecs, and forget a TBI specific intake. The single plane is the ticket IMHO.
Ohhh...and spray that bad girl! |
fiveoformula Member
Posted: Thu Mar 24, 2011 9:43 pm Post subject: |
Oh I see, do you the specs on your cam off hand? I know yours is going to be a 383 but still should be similar. |
Posted: Thu Mar 24, 2011 9:48 pm Post subject: |
I left that for the builder to decide, and he hasn't yet. I'll have a data-sheet for the motor when delivered which will have all the important stuff on it. I'll post the particulars when I get it. |
fiveoformula Member
Posted: Thu Mar 24, 2011 9:56 pm Post subject: |
I did see that one, it's a decent price too. its a little more than 6 inches high, I'll have to measure the stock one and see how much room I've got. |
Posted: Thu Mar 24, 2011 10:00 pm Post subject: |
Yeah, that seems a little. I did a quick google, and the Weiand I have, they say is 4.5" height at the back, 3.5" at the front. I'm not sure where the summit one is measured. But, i also have a nitrous plate, and the thicker style of adapter. With a thin plate, you could probably run a 5.5" okish with a 3 filter. The problem with TBI, is the stupid air cleaner bolt won't allow you to run much lower than a 3" element with a drop base, since with the taller intakes, you will need to remove the spacer ring, and then cut the top off the bolt. |
fiveoformula Member
Posted: Thu Mar 24, 2011 10:08 pm Post subject: |
I think I have a 3" filter on there now, along with a TBI spacer. That'll have to go for sure.
Why is it that single plane intakes usually have a much higher RPM range like 3,000-up? |
