coolant out the back?
miamivice
1982 Pontiac Trans Am
PostPosted: Thu Mar 24, 2005 10:37 am    Post subject: coolant out the back? Reply with quote
alright, having yet another problem w/ the TA.
yesterday i turned the car on and let it idle in the garage a few min and then backed it out.........went to close the garage door and saw there was some liquid on the floor right under where the exhaust was.
what all could be causing this??????????
thanks
PostPosted: Thu Mar 24, 2005 10:58 am    Post subject: Reply with quote
What kind of fluid? It is not uncommon for condensation to come out of the pipes when warming up. If it is just a little water I would assume condensation. Are your fluid levels still the same?
