Posted: Sat Jan 22, 2011 5:07 pm Post subject: I have air.... |
I know, not the right time of year for it, but for the first time since I've owned my red 89, it has working A/C $50 for a used compressor from kurfbird, about $30 for refrigerant (R134-a) and an hour's worth of labor. So a grand total just under $150, which includes the appropriate taxes.
Now I can dry out the warm air I'm blowing on the windshield to do a better job with defrost in winter, and be comfy in the summer _________________ 92 Camaro
Posted: Sat Jan 22, 2011 5:32 pm Post subject: |
Well you've just joined the old guys club... which reminds me.. mine quit working. It's like i'm young again! |
Whiskeychick Member
Joined: 19 Sep 2010 Posts: 225 Location: Penticton BC
1987 Pontiac GTA
Posted: Sat Jan 22, 2011 5:47 pm Post subject: |
Must be nice R134a, my R12 is starting to get warm _________________ 1987 - Trans am GTA, hooker headers, Borla catback, Cat delete, CAI, 9.6 @ 75mph 1/8mile
2008 - Mini Cooper Clubman S, Hot Chocolate on Hot Chocolate Lounge Leather |
Posted: Sat Jan 22, 2011 5:56 pm Post subject: |
-Schultzy |
Posted: Sat Jan 22, 2011 6:09 pm Post subject: |
Now the 92 needs to be serviced. It has R134-a already, but it's been a few years and it's starting to blow warm too. |
BigDaddyVu 12sec Club
Posted: Sat Jan 22, 2011 10:12 pm Post subject: |
a few years ago my first ac job on my t/a was simple but after awhile it didn't blow enough cold air out of the vent. last summer i decided to do it right, my friend a hvac guy helped me i had to change the orifice tube, air dryer and a new ac pump and fill the oil sump with 8 oz, flush the system seal it and used nitrogen gas to put it under pressure for atleast 24 hours put a vaccum pump with recovery tank on it for 36 hours check for psi drop and while under vacuum charge with 4 cans 134a and put adhesive heat wrap around my air dryer now it blows 34 degrees at the vent. it was a long and painful job changing every freaking o-ring with green o-ring _________________
Posted: Sun Jan 23, 2011 12:05 pm Post subject: |
Apparently, cold air isn't there yet. We knew the orifice tube needed replacing to use R134a, so for now, my air isn't any cooler than the vent setting. Come spring time, we'll recover the R134a, replace the tube, draw vacuum and recharge the system (which was the plan when I had this done). For the time being, I'm just concerned with dehumidified air going on the windshield for defrost. |
Posted: Sun Jan 23, 2011 12:16 pm Post subject: |
If it isnt getting cold, it isnt dehumidifying either. Lowering the temp, lowers the dew point and the moisture comes out of the air. A stock r12 orifice will work just fine for normal AC as well. The r134 or variable orifice are just better yet. I used a variable orifice and it does weird things..like cools better when you're parked idling then when driving 35mph. I've also frozen my windshield while driving with r134.
The filter/accumulator should be changed when you swap to r134. The dessicant bag inside may or may not be compatible with the new fluid. Also the stuff will go bad in normal use. One of the training seminars I went to, they went as far as to tell us that the filter should be changed every 2 years! LOL Like anyone would do that.
There's no need to change any o-rings that havent been disturbed. The old refrigerant oil has applied a coating to them that will block r134. A new r12 o-ring however will not stop r134 from leaking.
Vacuum need only be applied for 45min. Besides removing as much air as possible, the main reason for this is to boil any moisture out of the system. Moisture + refrigerant oil = acid.
I dont see where you applied vacuum. So you probably have too much air in the system for it to get cold. Either that or you have a blend door problem perhaps.
I've done lots of retrofits at work, but they have dried up now that the last r12 cars are so old. |
Posted: Sun Jan 23, 2011 12:27 pm Post subject: |
I had a vacuum pulled on the system after installing the compressor from I bought from Bruce. Replaced the O-rings on the compressor, then pulled the vacuum - drew it down for 15 minutes and it held for 30 minutes longer prior to charging the system. It blew pretty cold in the shop yesterday, but doesn't seem to today. The compressor still cycles, that tells me the system has enough refrigerant for it to work. |
Posted: Sun Jan 23, 2011 12:42 pm Post subject: |
Ahh. Just because it cycles doesnt mean its still full. R134 has alot different pressure curve then r12 did. A system can be almost empty and still cycle the compressor fairly well. It will also not cool well if you're even a couple oz's shy.
I would say you have a leak that you missed. |
Posted: Sun Jan 23, 2011 1:42 pm Post subject: |
I'm going to venture a guess to the same. It holds vacuum, but that doesn't necessarily mean it will hold pressure. It had to be evacuated and charged twice because one of the new fittings had a bad schrader valve and leaked as soon as the coupling was disconnected from the dryer on the first try.
By comparison, my V6 cycles on and stays on for a good 30-45 seconds or more before cycling off, this cycles on for a second or two before cycling off for about 5 or 10 seconds. I think most has leaked out under pressure. |
Posted: Mon Jan 24, 2011 5:53 pm Post subject: |
its hard to put 4 cans of 134a without the vacuum. While i was reaching on it my ac project. There coming out with a new refrigerant that will be required on future automobile and appliances could not remember I think its it 134 organic. _________________
Posted: Mon Jan 24, 2011 6:28 pm Post subject: |
You should only be putting 80% of the full R12 charge into a retrofit. |
Posted: Mon Jan 24, 2011 6:43 pm Post subject: |
4 cans = 3 lb of R134a refrigerant. Stock = ~2.4 lb of R12, 80% of that is ~1.9 lb R134a which mine was charged to. Making another visit to the shop to see where my leak is. |
Roshambo Member
Joined: 08 Jan 2004 Posts: 280 Location: Sacramento, CA
Posted: Tue Jan 25, 2011 12:12 pm Post subject: |
Damn, I thought someone else on here was running bags too. _________________ 1970 Cadillac Sedan DeVille Hardtop - 472/TH400, Air Bags with 10 switches, Memphis Audio.
90droptoproc Member
Posted: Tue Jan 25, 2011 12:40 pm Post subject: |
ya. me too
I think its just us though _________________
Roshambo Member
Posted: Wed Jan 26, 2011 6:03 pm Post subject: |
90droptoproc wrote: | ya. me too
I think its just us though |
What sorta setup are you running? |
90droptoproc Member
Posted: Wed Jan 26, 2011 10:45 pm Post subject: |
air over bags in the front, and 6"bags in the rear, two firestone compressors 10 switches plus keyless front up/down, rear up/down. single ten gallon tank _________________
Roshambo Member
Posted: Fri Jan 28, 2011 3:08 am Post subject: |
90droptoproc wrote: | air over bags in the front, and 6"bags in the rear, two firestone compressors 10 switches plus keyless front up/down, rear up/down. single ten gallon tank |
Nice. I've got two five gallon tanks and two Viair 480c's, but Ive been running one tank for awhile because of a faulty pressure switch. I ordered two new switches and starting tomorrow I am gutting the trunk, rerouting the air lines and installing both tanks. After that I'll be all done with my suspension. |
Posted: Fri Jan 28, 2011 5:10 am Post subject: |
Roshambo wrote: | Damn, I thought someone else on here was running bags too. |
I use to in my s10. It rode damn nice!!! _________________ 2008 GMC Z71
