redlava Member
Posted: Wed Jan 19, 2011 5:33 pm Post subject: Wheel stud installation |
I am currently attempting my ls1 front brake swap. I just got my hubs back from the machine shop. I have the 610-323 dorman wheel studs, with the .504 inch knurl. Do i need to drill the hubs or should I just press them in?
Thanks |
Posted: Wed Jan 19, 2011 5:54 pm Post subject: |
When I did it I just popped them in. _________________
MrMike98 Member
Posted: Wed Jan 19, 2011 6:14 pm Post subject: |
| i just did mine and i let the shop decide-they mic'ed and decided to drill out a little so there would be less chance of cracking a hub. |
Posted: Wed Jan 19, 2011 6:27 pm Post subject: |
If you need help, or a reference to look at (C5 is almost the same), I'm almost around the corner. I'm home most weekends. _________________ 92 Camaro
Posted: Wed Jan 19, 2011 7:08 pm Post subject: |
Drill is needed for the ARP wheel studs. Think it was like a 12mm bit.
The OEM replacements no drilling is necessary. Just brass hammer the bitches from the backside! _________________ A redline a day keeps the carbon away! |
Posted: Wed Jan 19, 2011 8:06 pm Post subject: |
| Twilightoptics wrote: | | Drill is needed for the ARP wheel studs. Think it was like a 12mm bit |
Good to know! I have a set of ARPs waiting to go in my new abs hubs. |
redlava Member
Posted: Thu Jan 20, 2011 6:14 am Post subject: |
| The dorman studs are over sized. I decided to drill out the holes using the 31/64 bit. I will let you guys know how it goes. |
redlava Member
Posted: Thu Jan 20, 2011 8:38 pm Post subject: |
| I did not drill the hole out to 31/64, I was already able to fit the bit through the hole. Everything went as planned using a vise and deep socket. |
