kurfbird Member
Posted: Sun Nov 28, 2010 5:37 pm Post subject: I know it not a third gen 85 Chevy Suburban 350 |
Okay was coming home from shoping on friday and the truck started surging going up a hill.
I am runiing and edelbrock 2101 intake and and edelbrock 1406 carburator. the carb was rebuild in april
Did a compression test getting 150-165 on all cylinders. before intake gaskets replaced. USe the edelbrock intake gasket
Installed new intake gaskets and torque them. Found some loose middle bolts so I thought that was the problem.
Also running a bowtie overdrive set up for the 700r4 transmission shift.
Installed new carb gaskets X2 . Still runs but cant acclerate.. Will idle surges while trying to drive it up hill.
I took the screw down to barly running and hit it with carb cleaner on the carb gasket no improvmemt. hit on the side of the carb near where the rods come out on drivers side car inproved on idle.
installed new fuel pump on friday
I just seem to be at a loss on what is going on here _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
Posted: Sun Nov 28, 2010 5:56 pm Post subject: Re: I know it not a third gen 85 Chevy Suburban 350 |
| How does the vacuum gauge look? How's fuel pressure? Is there slop in the throttle shafts on the carb? |
kurfbird Member
Posted: Sun Nov 28, 2010 6:09 pm Post subject: Vaccum |
Vaccum
is about 19 when carb is adjusted properly. top of the green scale.
Fuel pressure is 6-8 PSI. Buld my own fuel pressure tester. Cant seem to get one for carburator anymore.
Will check throttle shaft
Also forgot to add installed new fuel pump on friday _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Sun Nov 28, 2010 6:39 pm Post subject: |
Fuel Filter? _________________ A redline a day keeps the carbon away! |
kurfbird Member
Posted: Sun Nov 28, 2010 6:56 pm Post subject: New |
New also replaced on friday. There is some play in the throttle shaft. up and down if I grasp on it _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Sun Nov 28, 2010 8:12 pm Post subject: |
There's always some play in the throttle.. Vaccuum leak will make it not want to idle.
Is it a slow surge or quick jerk? Slow.. probably fuel supply. Check your pressure while driving .. tape gauge to windsheild. Quick its most likely something in the ignition. Cracked plug, wire, or cap causing crossfire under load. |
kurfbird Member
Posted: Sun Nov 28, 2010 8:25 pm Post subject: Okay |
But if I spray the side of the carb where the rods come out the car idles better when I ahve the front valves adjusted closed ?? _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Sun Nov 28, 2010 9:22 pm Post subject: |
Yes, because there actually is a leak there. But you can pretty much do the same to any carb, unless its a sealed blower carb. None are totally sealed there. The only time it is real trouble is if you can't adjust the idle mixture screws for a good idle. Or if the shaft is so worn the butterfly's rub the venturi. If you can adjust for a good idle then the leak will be compensated for all across the curve.
Was this running good and then went to crap? Or is this something that just happened all of a sudden?
From your description, i'd be looking at either the fuel pump or the pickup sock. It is possible to have an internal carb problem. But not likely.
A vacuum leak screws up the idle much worse then cruise. If you think about it. The amount of air in a leak is a much higher percentage of total air intake at idle, then at cruise. So the afr will be skewed lean alot more at idle then cruise. |
kurfbird Member
Posted: Sun Nov 28, 2010 9:40 pm Post subject: was running good |
Was running good and friday went to crap. Was not a slow problem it went bad very quickly. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Sun Nov 28, 2010 9:42 pm Post subject: |
I think that rules out the throttle shafts then.
Get your fuel pressure tester hooked up and take the rig out and try it. See if it holds pressure while the problem occurs. |
90droptoproc Member
Posted: Sun Nov 28, 2010 9:48 pm Post subject: |
| did you fill up right before this??? |
kurfbird Member
Posted: Sun Nov 28, 2010 9:48 pm Post subject: I will |
I will just depends when I get off work _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kurfbird Member
Posted: Sun Nov 28, 2010 9:54 pm Post subject: fill up |
| 90droptoproc wrote: | | did you fill up right before this??? |
No I did not but tank is pretty full 42 gallon tank _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
IROCDave Member
kurfbird Member
Posted: Mon Nov 29, 2010 7:19 pm Post subject: I think I found the problem |
I think I found the problem. A broken clamp that hold the fuel lines / hoses on teh frame near the gas tank. The hoses are getting pinched causing fuel to be restricted wont know for sure till I get it fixed. I though about it then look at it this morning before work with a flash light. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kurfbird Member
Posted: Mon Nov 29, 2010 8:46 pm Post subject: Okay I fixed the clamp still dooing the smae thing except |
Okay I fixed the clamp still doing the same thing except
When its cold and just started took it up the same hill near my house about 5 times
1 time good to go
2nd time surged a little
3rd surge more I adjusted carb 2.5 turns out.
4th time surge worse and stalled
5th time barly got up the hill. no power at all and tried to stall was worried about getting it home.
It runs worse as it warmed up.
I am think that its igntion related. Fuel I dont think would do that. Correcte me if I am wrong.
So its can probably be
Cap
Rotor
Coil
Igntion module Replaced in June
Spark plugs were repalced in June also (they looked good when I had them out for the compression test)
Wires (Got them new a less than a month ago) _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Mon Nov 29, 2010 9:01 pm Post subject: |
Is the tank venting right?
New means nothing. Don't assume its good because its new. |
kurfbird Member
Posted: Tue Nov 30, 2010 6:39 am Post subject: Tank vent |
It seems to vent okay but will run it with the cap loose and see waht happens _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Tue Nov 30, 2010 8:15 am Post subject: |
Adjustment screws you turned out only affect idle characteristics. _________________ A redline a day keeps the carbon away! |
