corey davidson Member
1986 Chevrolet Camaro
Posted: Sat Nov 27, 2010 12:36 am Post subject: Transmisson |
So, driving home the other day. I come off hw22 and my truck starts clanking and loosing power. Next thing I know I have no transmission. Now, I get towed home (a block form my house) jack the truck up , take the scatter shield off find out that the transmission was only held on by 3 bolts, really wasn't in a good mood after that but than the flashlight came out and the flywheel had exploded.So long story short now i need a new transmission. and the moral of the story is don't by a truck from a crazy old guy that has had transmission work done at keizer transmission _________________ real men are covered in oil and grease |
91camaro_rs Member
Posted: Sat Nov 27, 2010 12:49 am Post subject: |
i think donald has a V6 T5 _________________
Posted: Sat Nov 27, 2010 12:51 am Post subject: |
I found a couple but don't have the cash. The damn truck couldn't have waited 2 more weeks after school was over _________________ real men are covered in oil and grease |
popballz Member
Posted: Sat Nov 27, 2010 3:15 am Post subject: |
| 91camaro_rs wrote: | | i think donald has a V6 T5 |  _________________ -Donald
Posted: Sat Nov 27, 2010 7:21 am Post subject: |
| I may be missing something here, but if the flywheel is cracked/damaged, why not just get a resurfaced one, a new clutch kit, and go with it? Did it take out the input shaft or something? |
Posted: Sat Nov 27, 2010 9:14 am Post subject: |
Yeah. You need a flywheel or clutch.
Did the flywheel come apart or the pressure plate or the clutch disc?
Is this a manual or auto?
n00b. _________________ A redline a day keeps the carbon away! |
Posted: Sat Nov 27, 2010 3:43 pm Post subject: |
its an auto and it exploded ill take a pic when i get it out but the rain is halting all of that.I'v pulled out 3 1 in peaces out of the scatter shield _________________ real men are covered in oil and grease |
Posted: Sat Nov 27, 2010 4:48 pm Post subject: |
What happened to that S10 shortbox you traded for? I thought it was a stick?
Regardless, it sounds like you only need a flexplate. Should be able to pick one up at the JY pretty cheap. Gotta get the right balance, though. Some of those 60* motors were balanced differently than others. |
Posted: Sat Nov 27, 2010 6:37 pm Post subject: |
the guy didnt wanna trade after i put a crap load of money in to making the truck what he wanted. I'm just gonna get a t5 for it i think _________________ real men are covered in oil and grease |
Posted: Sat Nov 27, 2010 10:02 pm Post subject: |
Isn't the flexplate of the 2.8s known for grenading? I know two jeep guys that blew up flexplates with their 2.8 Cherokees. _________________
Posted: Sun Nov 28, 2010 2:44 pm Post subject: |
its the same engine that's in the birds and maros iv never seen one do this . i have head of them busting in the 2.8 jeeps thats why you should buy 4.0high output _________________ real men are covered in oil and grease |
Posted: Sun Nov 28, 2010 2:50 pm Post subject: |
| 2.8 in a jeep is the same GM motor. There's a couple cheap cherokees on craigs right now being parted out. One I know was a 2.8 5spd. Might be a place to get parts. |
Posted: Sun Nov 28, 2010 2:55 pm Post subject: |
Jeep T5's are different than S-10 or F-Body t5s. _________________ A redline a day keeps the carbon away! |
Posted: Sun Nov 28, 2010 3:27 pm Post subject: |
| Interesting. Since they bolt to a 2.8 that end will evidently bolt up. Where's the actual change? Made for a different transfer case? |
Posted: Sun Nov 28, 2010 3:39 pm Post subject: |
They tend to have more of a mopar input shaft. Pretty sure they use the T5 in more than just the 2.8GM motor. Cause they also use them behind the 2.5L Cry I4. And the t-cases are make specific so it probably has a different tail with 4x4 versions. _________________ A redline a day keeps the carbon away! |
Posted: Sun Nov 28, 2010 4:04 pm Post subject: |
| The one I saw on craigs was a 2.8 gm motor. So evidently input will work. Question on the shifter and transfer case however. |
Posted: Sun Nov 28, 2010 10:49 pm Post subject: |
Cool that just answered my next question if the 2.8 jeeps trans would work on my 2.8 blazer _________________ real men are covered in oil and grease |
