GM turn signal lever with cruise
PostPosted: Sun Oct 31, 2010 3:50 pm    Post subject: GM turn signal lever with cruise Reply with quote
Anybody have an actual delco turn signal lever? I'm on my 5th.. 6th? I've lost count.. aftermarket lever. The cruise control set button keeps shooting out of the damn things. Friday I went to signal right and the button shot out and hit the window. Anyway, i'm tired of aftermarket.
Whiskeychick
1987 Pontiac GTA
PostPosted: Sun Oct 31, 2010 5:11 pm    Post subject: Reply with quote
Dont have one on hand, but ill keep an eye out up here.
PostPosted: Tue Nov 02, 2010 8:42 am    Post subject: Reply with quote
i'm with you Brandon. I usually get two years out of the cable that snakes through the column, after that they fail and need to be replaced. i have also had buttons come flying out. My GTA is on it's 3rd and I have only owned it 5 years. i buy from Baxter and save my receipts... lifetime satisfaction guarantee. Twisted Evil
PostPosted: Tue Nov 02, 2010 12:00 pm    Post subject: Reply with quote
Same thing happened to me 3 days ago. Too bad my cruise doesn't work anyway.
PostPosted: Tue Nov 02, 2010 4:39 pm    Post subject: Reply with quote
would a 4th gen cruise/wiper/signal lever fit? I've had my car for 6 years (although I don't use cruise control much...) and mine's never had any issue whatsoever.
PostPosted: Tue Nov 02, 2010 5:47 pm    Post subject: Reply with quote
4th gens are a multifunction switch arent they?
Just this little statistical sample shows that the aftermarket has a a real problem with these things. Whats the odds of 2 guys having the same problem within a week of each other in a group this size? Neither of us were actually using the cruise either!
I don't think I've seen the button issue with the delco units.. just the cord getting cut at the washer selector. So I hope one would last longer.
PostPosted: Wed Nov 03, 2010 8:25 pm    Post subject: Reply with quote
AFAIK, Brandon, the non-cruise 4th gen intermittent wiper lever PN was the same for 3rd gen. (that's what's in my 86) I would suppose that the PN's for 3rd and 4th gen cruise levers would be the same.
PostPosted: Wed Nov 03, 2010 10:24 pm    Post subject: Reply with quote
Did some investigating and it looks like the 89-92 3d gens use a different lever then the earlier ones. Not sure what is different. But I know that one time I got the wrong lever.. everything looked right.. but when I set the cruise.. i got unlimited acceleration! Warp speed scotty. Luckily turning off the cruise released the gas pedal! Laughing
PostPosted: Thu Nov 04, 2010 4:11 am    Post subject: Reply with quote
The lever in my 89 is slightly different than my 92. The only difference I can tell is the wiper delay function. The 92 has clicks for the different speeds and the 89 is infinite (no clicks). Don't know if cruise is wired different though.
