BigBoi4Lyph Member
Joined: 10 Jun 2007 Posts: 233 Location: Olympia, Washington
Posted: Sun Jul 11, 2010 9:34 am Post subject: T-5 manual for v8 needed! |
So i just rebuilt my non world class and its already on its way out. Aparently the fourms wernt kidding about the non WC t-5's behind the 5.7 tpi...
So ill take anything at this point that is in good useable not makeing noise condition!
I would prefer the world class but shoot me a response or pm with what you may have.
Maybe even a t56 for the right price??
Thanks! _________________ 87 Camaro Z28 - Iroc-Z |
Posted: Sun Jul 11, 2010 9:48 am Post subject: |
Hate to be the guy to say it... But if the gears were in good shape, you set the main shaft end play properly, and used good rebuild wear parts it'll hold a mild 350 TPI just fine. High hp clutch drops and sticky tires... Not so much.
Wc t5 is marginally stronger. The upgrades that make it world class are for milage longevity. _________________ A redline a day keeps the carbon away! |
BigBoi4Lyph Member
Posted: Sun Jul 11, 2010 10:03 am Post subject: |
Yea for sure it was my first rebuild so im sure it wasnt perfect. but i also drive the car sideways...
it also could have been the cheap ebay rebuild kit i got for it. its deffinatly the bearings makeing noise _________________ 87 Camaro Z28 - Iroc-Z |
Posted: Sun Jul 11, 2010 10:13 am Post subject: |
| BigBoi4Lyph wrote: | Yea for sure it was my first rebuild so im sure it wasnt perfect. but i also drive the car sideways...
it also could have been the cheap ebay rebuild kit i got for it. its deffinatly the bearings makeing noise |
Did you remove the torque arm off the tail shaft?
Your rebuild may might have sucked also, they aren't that weak.  |
BigBoi4Lyph Member
Posted: Sun Jul 11, 2010 10:18 am Post subject: |
torque arm still in factory location. _________________ 87 Camaro Z28 - Iroc-Z |
Posted: Sun Jul 11, 2010 11:15 am Post subject: |
Could be your throw out bearing. Did you set end play? The input bearings go to shizzle if you don't have enough oil. Cheap bearings tend to be noisy also. _________________ A redline a day keeps the carbon away! |
BigBoi4Lyph Member
Posted: Sun Jul 11, 2010 11:31 am Post subject: |
Its deffinatly a bearing in the transmission. When i rebuilt it one of the teeth on the countershaft musthave gotten chipped on 2nd gear becuase since the rebuild it had a 2nd gear chattering on the coast side of the gear. so at this point im just going to get another used transmission untill i can get a t56 to swap in.
I didnt set end play I used the original shims and just matched everything back up but that oviously didnt work so well.  _________________ 87 Camaro Z28 - Iroc-Z |
Posted: Mon Jul 12, 2010 12:39 pm Post subject: |
My NWC T5: Very abused.
Functionality: Perfect. No problems at all.
Noises: Oh God the grinding/rattling/whining will it ever stop!!??
Been exactly this noisy for about 40k miles, ever since I got the car. Bought it from very abusive rednecks who managed to blow up the 305 at 67k miles. I abuse it with my HSR 355. No problems. No traction, which is why it lives as Paul said.
More fun than an automatic any day of the week. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Jul 12, 2010 5:32 pm Post subject: |
I'm with Gabe on this one. The NWC T5 in my old S10 (beat on by me and the previous owner, but survived due to being behind a six) made all kinds of weird noises. Always shifted fine, though.  |
townaj Member
Posted: Tue Jul 13, 2010 6:29 pm Post subject: |
I got a NWC T5 behind my 383 and its doing fine so far(fingers crossed, knock on wood, etc.), just like (almost) everyone else's. No weird noises, but it does grind going into third sometimes. And I never go light on the throttle . I think your probably alright with a little noise. Have fun with it! |
Posted: Tue Jul 13, 2010 7:03 pm Post subject: |
I have a well built NWC T5 for sale on the for sale board.
BigBoi4Lyph Member
Posted: Wed Jul 14, 2010 12:50 pm Post subject: |
Alright ill settle for another non WC then! Its so weird on this board everyone is running the non wc and have good things to say. when I did my reaseach probably a year and a half ago now on TGO everyone was talking about not even putting the non wc behind a stock 5.7 tpi if you drive it even remotly hard...
And pmed Schultzy! _________________ 87 Camaro Z28 - Iroc-Z |
townaj Member
Posted: Wed Jul 14, 2010 4:08 pm Post subject: |
| I heard the same thing. But then looked at prices...300 bucks more for a rebuilt WC! So i decided to go NWC and baby it. So much for babying it...hope it works out for ya! |
Posted: Wed Jul 14, 2010 5:30 pm Post subject: |
| BigBoi4Lyph wrote: | | Alright ill settle for another non WC then! |
Er... not to be a dick, but how much do you want for your T5 core? |
BigBoi4Lyph Member
Posted: Sun Jul 18, 2010 6:34 am Post subject: |
I was a actually going to sell the core anyways. I was thinking 60 bucks? I already installed Mikes t5 that's I picked up works great now! Thanks _________________ 87 Camaro Z28 - Iroc-Z |
Posted: Sun Jul 18, 2010 1:53 pm Post subject: |
| BigBoi4Lyph wrote: | | I already installed Mikes t5 that's I picked up works great now! |
Glad to hear it. That Hurst shifter is nice eh?
BigBoi4Lyph Member
Posted: Sun Jul 18, 2010 5:46 pm Post subject: |
Yea it's deffinatly nicer I like how it feels no play or wiggle room at all. I thought it might have still had a shorter throw but it's just a little less then stock from forward to rear gears. Still a huge upgrade tho! Thanks! _________________ 87 Camaro Z28 - Iroc-Z |
alloy T56 Elitist
Posted: Sun Jul 18, 2010 8:59 pm Post subject: |
That's the third crew car that trans has been in. Is that a new record for a trans swap???
Never dreamed when I built that trans it would make the rounds like it has. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
