Exhaust maifold gasket fun
PostPosted: Sat Jul 03, 2010 7:44 pm    Post subject: Exhaust maifold gasket fun Reply with quote
I forgot how much interference had to be removed to get the exhaust manifolds out. Both my gaskets in the V6 are leaking, as well as the donut. I got the driver side out and installed a new Remflex gasket, but to get there, I had to undo accessories so I could undo brackets, so I could undo more brackets Shocked After moving the A/C compressor and power steering pump out of the way and removing their brackets, old gasket is out and new one in. I am not looking forward to the passenger side with all the A.I.R. crap to move along with the EGR which is attached to the manifold.
The old piece looked like this when I finally got it out.
PostPosted: Sat Jul 03, 2010 7:51 pm    Post subject: Reply with quote
Time for headers. Very Happy
PostPosted: Sat Jul 03, 2010 8:01 pm    Post subject: Reply with quote
Crap like that can happen, even with headers...
PostPosted: Sat Jul 03, 2010 8:02 pm    Post subject: Reply with quote
Try it on a V8 with AC Mad
PostPosted: Sat Jul 03, 2010 8:06 pm    Post subject: Reply with quote
And I was just going to ask how that would solve my gasket problem Laughing
I think the Remflex gaskets will do the trick, but I might have to take out the connecting pieces between the ports so I can put the plugs in without fighting the gasket material just hanging there.
Trust me, John, I ran Flowsuck headers on my IROC, I'm plenty familiar with that exact picture right there. Wink
I;m just saying, while he's got it all apart...
PostPosted: Sat Jul 03, 2010 8:09 pm    Post subject: Reply with quote
I did that on my 89 when I installed the headers Cool
PostPosted: Sat Jul 03, 2010 11:42 pm    Post subject: Reply with quote
Man guys, my headers come right out... Razz Easy peasy. I have nothing bolted to or around them though, a little different than your experiences.
Remflex are the best exhaust gaskets in the world. Thumbs up
91camaro_rs
PostPosted: Sun Jul 04, 2010 11:02 am    Post subject: Reply with quote
i didnt even have gaskets on my v6 and i had no leaks
PostPosted: Sun Jul 04, 2010 11:03 am    Post subject: Reply with quote
If your manifolds are nice and true, no gaskets is the way to fly. Nothing to blow out.
PostPosted: Sun Jul 04, 2010 12:29 pm    Post subject: Reply with quote
Yep get them mani's surfaced and install without gasket just like gm intended.
PostPosted: Sun Jul 04, 2010 3:38 pm    Post subject: Reply with quote
What's the cost of that? About the same as gaskets? Anyway, I'm not pulling them off again Cool
Only piece I couldn't find anywhere is the gasket that goes to the EGR riser (the pipe the EGR sits on top of) where it mounts to the manifold.
PostPosted: Sun Jul 04, 2010 6:03 pm    Post subject: Reply with quote
Depends on the place. Anywhere from $50-$80 for the pair.
PostPosted: Sun Jul 04, 2010 6:43 pm    Post subject: Reply with quote
Maybe next time. I could get two to three sets of the gaskets I have for that. These shouldn't leak, unless the unlikely damage on install, and once installed, the bolts never need to be re-torqued. I have the same brand gaskets on the 89's headers, and haven't touched the bolts since install.
PostPosted: Mon Jul 05, 2010 8:08 pm    Post subject: Reply with quote
You're just biased against Flowtech because they were so much fun to install on my T/A! Laughing
PostPosted: Mon Jul 05, 2010 8:11 pm    Post subject: Reply with quote
Say John, when you and James put those turds cleverly disguised as headers on your Trans Am, you just used the paper "gaskets" didn't you? Razz
PostPosted: Mon Jul 05, 2010 8:14 pm    Post subject: Reply with quote
No, they were the steel layered ones that either the previous owner provided or that I got from Ian. They were three pieces per side, not one big one like in the above pic.
PostPosted: Mon Jul 05, 2010 8:18 pm    Post subject: Reply with quote
Those might get you a few miles with the FlowSucks. Before I went with Remflex gaskets on mine, I was blowing double-stacked Mr. Gasket papers (another fine company that doesn't make total crap Rolling Eyes) with regularity at around 500 miles.
PostPosted: Mon Jul 05, 2010 8:22 pm    Post subject: Reply with quote
500 miles will take like 3 years for John. Smile
PostPosted: Mon Jul 05, 2010 8:27 pm    Post subject: Reply with quote
True! The T/A isn't gonna see alot of road time. Just summer weekend cruising and car shows. Cool
