IROC-stangs Member
Posted: Fri Jun 25, 2010 8:57 pm Post subject: starter??? |
| ok a while ago i went out to start the camaro and now it wont start. it making a high pitch buzzing/rapid tapping sound and do you think its from not shimming the starter? i just replaced that (and yes it had a crack on the siloneid. so if its the starter how do i shim it properly? thanks. |
Posted: Fri Jun 25, 2010 9:07 pm Post subject: |
| Not a very discriptive explaination. But, if the battery is low, it will do some funky and sound like that (maybe, your quick tapping, and mine might be different). |
Posted: Fri Jun 25, 2010 9:13 pm Post subject: |
I was thinking the same thing about the battery being low. _________________ 92 Camaro
IROCDave Member
Posted: Fri Jun 25, 2010 9:14 pm Post subject: |
Did it start after the new starter / solinoid install? Might be a really bad alignment but more than likely it is a chipped tooth on the flywheel? Put a socket/ breaker bar on the crank pulley snout and turning it a couple of degrees, remove the socket / breaker bar and try starting it.
If it starts without the noise, replace the wring gear. If not, replace the starter with one that hasnt been rebuilt 10 times by south Americans.
Trust me, life time warranties on hard use parts are useless. Purchase original parts manufactured to original specifications. This will make sense when you are laying on your back on a Sunday night trying to get your dailey driver running so you can get to work Monday. |
Posted: Fri Jun 25, 2010 9:24 pm Post subject: |
If it was in need of shims from the time you installed it, it probably would have sounded like a bag of cats.
My two cents is on a low (but not dead) battery. |
IROC-stangs Member
Posted: Fri Jun 25, 2010 10:39 pm Post subject: |
| thanks guys. it sounds NOTHING like a low battery though and it sounds like gears hitting together or something. i need to get a new one anyhow and got it pretty much out. thanks. |
Posted: Fri Jun 25, 2010 11:07 pm Post subject: |
| If it's still the cracked one, just pull it. As Dave mentioned, don't just buy the Blatozone crap, buy a good one, or a junkyard one. |
Posted: Sun Jun 27, 2010 12:07 pm Post subject: |
The solenoid will chatter if voltage at the solenoid is not sufficient to hold the pinion extended during crank. It is often due to weak batteries.
Battery voltage decreases as current draw increases.
1. The solenoid current draw is not very high and it can pull in just fine.
2. When the starter motor begins to crank the current draw goes way up and battery voltage drops. The voltage is too low to keep the solenoid engaged and it drops out.
3. The starter stops cranking and the battery voltage recovers. The solenoid is still being given a crank command so it goes right back in and the process repeats itself over again from the beginning.
Solenoid chatter will destroy the contacts in the solenoid in a hurry because DC current arcs when you make and break contact. You end up getting metal transfer and melting of contacts. If you end up having intermittent starting problems later on then you can attribute it back to this event. |
Posted: Sun Jun 27, 2010 4:47 pm Post subject: |
You heard him guys!
| IROC-stangs wrote: | | it sounds NOTHING like a low battery though |
