power windows-slooooow why?
MrMike98
PostPosted: Sat Jun 19, 2010 7:36 am    Post subject: power windows-slooooow why? Reply with quote
it can only be a few thinks and they all require one to pull door apart.
can motor be weak,?
spring counterbalance weak?
bushing rollors bad?
dirt?
questions is, what is the most common cause for the windows to start slowing down and then u have to "help" the glass up, etc.?
and of course any fixs to above.
since i have doors striped for painting, might as well take care of these other issues.
thanks
mike
PostPosted: Sat Jun 19, 2010 7:39 am    Post subject: Reply with quote
Motor usually, though you can help them out for awhile by lubing the tracks and using silicone in the channels.
PostPosted: Sat Jun 19, 2010 7:47 am    Post subject: Reply with quote
If you've got everything striped out, re wire the window motors. Run the PW switches to some heavy duty relays and 10g+ wiring. The stock stuff is like 12 or 14g? That coupled with a NEW motor and you should have some decently quick windows (as compared to a regular thirdgen).
For motors I had used cardone's reman a couple times and tried a siemens brand new one for just a couple dollars more and it was a night and day difference, quiter, smoother, faster.
MrMike98
PostPosted: Sat Jun 19, 2010 4:08 pm    Post subject: Reply with quote
just looked at what it takes to install new PW motor. its like a hole summer long job just for the doors..
I may have to farm some of this work out. i hate that. but it seems like a daunting task to completly strip out the door, BUT wait u have to put it all back together(right) and then "adjust" window etc. etc. etc.
so who has done this job and knows the short cuts??
and NO i donot what to use a plasma cutter on the outer door panel.. Smile
OK im there bitching, i could have been done by now.
thanks Mike
PostPosted: Sat Jun 19, 2010 4:23 pm    Post subject: Reply with quote
About the time you get the job done you have it down to a science and its easy.. then you'll forget all about how its done by next time.
MrMike98
PostPosted: Sat Jun 19, 2010 4:38 pm    Post subject: Reply with quote
of course-
it will take me 3 days for the first door and about 1-1/2 hrs or the second, ~18 drinks, 6 band aids and 1/2 bottle of proxiode. OH and if u are with in ear shot u need to wear anti swear word ear protection.
kurfbird
PostPosted: Sat Jun 19, 2010 8:36 pm    Post subject: Power windows Reply with quote
Get a rivit gun larger than the ones from ace or other hardware store. Got mine from Harbor Freight for like 15.00
First one did with out the correct rivts. Used bolts and self locking nuts
PITA then got the rivit gun speeded up the process. They even supply rivits for the gun
http://www.harborfreightusa.com/usa/itemdisplay/displayItemList.do?search.keyword=rivit+
Large Capacity Hand Riveter
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Sat Jun 19, 2010 9:07 pm    Post subject: Reply with quote
^ This x eleventy-billion.
Personally I would try rewiring them first and see what that gets you, unless the motor is actually stopping and you have to pull the window up.
IROCDave
PostPosted: Wed Jun 23, 2010 3:44 pm    Post subject: Reply with quote
Havent had to do this yet but both of my cars have slow drivers side windows. Can you jump 12 volts ( spare battery) straight to the window motors to test them before rewiring?
PostPosted: Wed Jun 23, 2010 4:35 pm    Post subject: Reply with quote
Yup. Yup yup Just remember that they're two wire motors, not three, so reverse polarity to reverse the motor.
PostPosted: Sun Jun 27, 2010 10:42 pm    Post subject: Reply with quote
We're going to have to try that on my T/A too, Aaron. The windows are redonkulously slow! Sad
MrMike98
PostPosted: Tue Jun 29, 2010 6:43 pm    Post subject: Reply with quote
Just replaced drivers side motor, and cleaned and relubed tracks..all hardware seems to be in good shape, so the no window installed it now works Great. Smile .
i replaced the cheap nuts and bolts that came with motor with good grade hardware and locktite with lock nuts, I hope thats enough.
Mike
PostPosted: Tue Jun 29, 2010 7:09 pm    Post subject: Re: power windows-slooooow why? Reply with quote
Most common cause for window motor failure in a thirdgen is the driver hooting at equally classy women. Other common causes are spitting, and Taco Bell drive thru. The window operating duty cycle is way beyond anything GM ever planned for.
IROCDave
PostPosted: Wed Jun 30, 2010 7:21 pm    Post subject: Reply with quote
Qwktrip, you would be suprised at what class of chic you can pull with a clean 3rd gen Very Happy Well, 15 years ago you could do it, not sure about today. I met my wife becuase she cut me off while racing a 911 on Rose Hill in Kirkland 15 years ago. I didnt know it was a ditzy blond chic driving the slow RX7 with deep tinted windows when I pointed to the Al's auto parts parking lot. 1 month later that POS RX7 was gone and she had a 95 Firebird.
PostPosted: Wed Jun 30, 2010 7:50 pm    Post subject: Reply with quote
My ex bought an '85 Z28 shortly after we started dating just to impress me! She really knew the way to my heart! Very Happy
BTW, Thread Jacked
