flea Member
Posted: Fri May 21, 2010 9:59 am Post subject: park switch |
simple question I hope, but I need the windshield wiper park switch. It has been discontinued from GM and can only be sourced through wrecking yards etc. This Saturday I plan on getting out to Tumwater to see if I can find one, the question is; is this part a third gen F-body specific part or can I get one off of some other GM vehicle like a minivan or something along those lines. _________________ Killing mailboxes since 2009 |
flea Member
Posted: Fri May 21, 2010 11:09 am Post subject: |
I need that park switch, I have a new motor already. I will look for one from a Camaro, but they get picked over pretty clean by the sounds of it, so I thought that if I found a caddy or something like that i could grab that. Guess it doesn't matter much I'll just look and see what I can find. _________________ Killing mailboxes since 2009 |
Posted: Fri May 21, 2010 11:37 am Post subject: |
The one thing I've noticed there is plenty of at the Tumwater PAP at least, is wiper motors and wiper parts. Seems like nobody takes those. So good luck, you might get what you need.  _________________ 84 Camaro Z28 - LS1/T56
