Tony86 New Member
Posted: Thu Jan 20, 2005 10:18 pm Post subject: Question on a V6 |
Does anyone know about how much it would be to rebuild a V6 on a 1986 firebird? I just need a ball park range. I dont know what is wrong with it. All I know is, that its not running because its been sitting for too long, about 2 1/2 years and it wont start now. |
Posted: Thu Jan 20, 2005 11:16 pm Post subject: |
I think it'd be hard to asses the cost. You'd really need to know what's wrong with it. Heck, it could be a blown fuse or something...? _________________
Midnight Sun Member
Posted: Fri Jan 21, 2005 12:46 am Post subject: |
iansane wrote: | I think it'd be hard to asses the cost. You'd really need to know what's wrong with it. Heck, it could be a blown fuse or something...? |
Yeah, it could really range from something as simple as a dead starter, to a blown headgasket. _________________
Posted: Fri Jan 21, 2005 1:03 pm Post subject: |
Agreed. If it ran before, it will run again. Run through the check list and do a tune up,
Fuel? Spark? Timing? Moisture? etc |
Glenn91L98GTA Member
Joined: 21 Oct 2004 Posts: 25 Location: Kamloops, BC Canada
Posted: Sun Jan 30, 2005 6:55 am Post subject: |
The biggest problem with a car that sits for a long period is the injectors get clogged and your fuel turns to crap.
First, DRAIN THE TANK. And then put fresh gas in. Then be prepared to take those injectors in for a good cleaning.
Start there.
Then, install all good plugs, wires, cap & rotor on the spark side. |
