| should i keep the green LED'S? |
| yes |
0% |
[ 0 ] |
| not worth the trouble |
100% |
[ 12 ] |
| Total Votes : 12 |
cameron7710 Member
Posted: Tue May 04, 2010 8:42 pm Post subject: How much trouble do u think i would get in? |
well i got some led's to replace the burntout gauge lights i have (finally ) and i bought 2 settes of 10 so i have a few spares so i just got thinking about how cool they would look in the license plate lights so i put some in and it looks hella sick. but im pretty sure i will get pulled over alot so i thought id get your guys opinions. o and honestly u can read the plate better now befor you could only read the first and last 2 letters _________________
d00012 Member
Posted: Tue May 04, 2010 8:47 pm Post subject: |
I do believe they are supposed to be white. _________________
Posted: Tue May 04, 2010 9:13 pm Post subject: |
| d00012 wrote: | | I do believe they are supposed to be white. |
You are correct, sir.
| Quote: | RCW 46.37.100
Color of clearance lamps, side marker lamps, back-up lamps, and reflectors.
(1) Front clearance lamps and those marker lamps and reflectors mounted on the front or on the side near the front of a vehicle shall display or reflect an amber color.
(2) Rear clearance lamps and those marker lamps and reflectors mounted on the rear or on the sides near the rear of a vehicle shall display or reflect a red color.
(3) All lighting devices and reflectors mounted on the rear of any vehicle shall display or reflect a red color, except the stop lamp or other signal device, which may be red, amber, or yellow, and except that on any vehicle forty or more years old, or on any motorcycle regardless of age, the taillight may also contain a blue or purple insert of not more than one inch in diameter, and except that the light illuminating the license plate shall be white and the light emitted by a back-up lamp shall be white or amber.
[2002 c 196 § 1; 1992 c 46 § 1; 1961 c 12 § 46.37.100. Prior: 1955 c 269 § 10; prior: 1947 c 267 § 3, part; 1937 c 189 § 17, part; Rem. Supp. 1947 § 6360-17, part; RCW 46.40.040, part; 1933 c 156 §§ 5, part, 6, part; 1929 c 178 §§ 7, part, 8, part; 1927 c 309 §§ 27, part, 28, part; RRS §§ 6362-27, part, 6362-28, part; 1921 c 96 § 22, part; 1919 c 59 § 10, part; 1917 c 155 § 15, part; 1915 c 142 § 21, part.] |
I highlighted blue the license plate requirement.
And for those of us with clear (or smoked) side markers, read the first paragraph, I think we're OK with the display color  _________________ 92 Camaro
Posted: Tue May 04, 2010 9:51 pm Post subject: |
Cops are pissed if your license plate lights are anything but yellow/white. I threw a bunch of white LEDs in my license plate lights. _________________
Posted: Tue May 04, 2010 9:59 pm Post subject: |
Yellow/White = Warm White, as opposed to natural (pure white) or cool (blue) whites.  |
cameron7710 Member
Posted: Tue May 04, 2010 10:05 pm Post subject: |
ya i probley should just take them out since i get hassled by cops enough. plus as much as i dont like to think people are that stupid i dont think is worth geting rear ended when somone sees a green light  _________________
Posted: Tue May 04, 2010 11:20 pm Post subject: |
| cameron7710 wrote: | | ya i probley should just take them out since i get hassled by cops enough. |
Ya think?!?!?!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
cameron7710 Member
Posted: Wed May 05, 2010 3:28 pm Post subject: |
ok so i put the stock bulbs back in for now and ordered some white LED's _________________
Posted: Wed May 05, 2010 4:27 pm Post subject: |
Where are you getting the LED's from, and what kinda customer service you getting?
Been thinking about doing some of this myself. The truck seems to love blowing bulbs. |
Posted: Wed May 05, 2010 4:47 pm Post subject: |
If you have bulbs failing often you have a problem!
Superbrightleds.com is a great place. _________________ A redline a day keeps the carbon away! |
