Posted: Sun Mar 28, 2010 5:11 pm Post subject: 1988 1500 relays |
Does anyone have an 88 chevy pickup? I have a relay right next to the blinker relay on the bottom of the relay block that is stuck on. It doesn't seem to actually do anything. But key on or off it clicks on and it's drawing 100mA which is killing the battery. I can't seem to find a diagram anywhere of what it does.
Anyone have a clue? _________________ E30
Posted: Sun Mar 28, 2010 5:13 pm Post subject: |
| Horn? |
Posted: Sun Mar 28, 2010 5:25 pm Post subject: |
All data agrees with Aaron. _________________
Posted: Sun Mar 28, 2010 9:35 pm Post subject: |
so next question... does your horn honk? if not that is because it was stuck on the prior owner cut a wire to make it stop. if so... genuine mystery.  |
Posted: Mon Mar 29, 2010 8:12 am Post subject: |
| Thanks guys! After I verified that the horn doesn't work I asked the owner if he's had horn problems. He said that one day he was talking on the phone in his truck and horn kept randomly honking. He drove it home like that and then cut the wire to the horn! So the wiring somewhere got messed up and while the horn didn't honk anymore, the relay was energizing. So I left the relay in the glovebox for now. Thanks a bunch! |
Posted: Mon Mar 29, 2010 8:17 am Post subject: |
horns are over-rated. That is why humans have middle fingers.
*CC.org does not in anyway encourage or endorse any form of escalation or road rage |
Posted: Mon Mar 29, 2010 8:23 am Post subject: |
In my entire life I have only ever owned two vehicles that actually had working horns. And both of them were 90's Fords.
My guess would be that the horn initially grounded out in the steering wheel pad, causing it to honk randomly (common problem on old Chebbies ). Then when he cut the wire under the hood it grounded out, causing a short circuit. |
Posted: Mon Mar 29, 2010 9:46 pm Post subject: |
| i just recently fixed my GTA horn, it has not worked since the weekend before the Klamath Falls cruise we did last summer. |
Posted: Mon Mar 29, 2010 10:11 pm Post subject: |
Tony, that was two summers ago. It was Labor Day 2007
Guess you've been without a horn for a while  _________________ 92 Camaro
Posted: Tue Mar 30, 2010 2:38 pm Post subject: |
| Xophertony wrote: | | i just recently fixed my GTA horn, it has not worked since the weekend before the Klamath Falls cruise we did last summer. |
now fix 5th gear. _________________
Posted: Wed Mar 31, 2010 7:11 am Post subject: |
| Quasi-Traction wrote: | | Xophertony wrote: | | i just recently fixed my GTA horn, it has not worked since the weekend before the Klamath Falls cruise we did last summer. |
now fix 5th gear. |
Tony, I read that it's probably just the 5th gear retaining clip that came off. Might be worth yanking out and fixing when you get the V6 car running. _________________ 84 Camaro Z28 - LS1/T56
TurdGen1989 Member
Posted: Wed Mar 31, 2010 8:51 am Post subject: |
| Dewey316 wrote: | horns are over-rated. That is why humans have middle fingers.
hahahah _________________ Phil.
GMC High Sierra
