Posted: Wed Mar 24, 2010 8:38 pm Post subject: |
a little steep but i am WAY in the market for a transmission right now. are the LS1 t56s the ones that use the same style of clutch, or is that the LT1 T56s. _________________ 86' firebird (Junked in 2015). 88' GTA (sold in 2020).
Posted: Wed Mar 24, 2010 8:47 pm Post subject: |
| That's the one you want if you're keeping your T5 stuff, Tony. |
Posted: Wed Mar 24, 2010 11:35 pm Post subject: |
I say too much for a trans you don't know is good or not.
Although for some reason t56s have gone up in price over the last year or so.  _________________
Posted: Thu Mar 25, 2010 7:31 am Post subject: |
Dang, I want that. Can't afford it right now though. That's what I need. _________________ 84 Camaro Z28 - LS1/T56
Posted: Thu Mar 25, 2010 7:57 am Post subject: |
| Alphius wrote: | | Dang, I want that. Can't afford it right now though. That's what I need. |
Quoted For Truth |
Posted: Thu Mar 25, 2010 9:18 am Post subject: |
| Xophertony wrote: | | Alphius wrote: | | Dang, I want that. Can't afford it right now though. That's what I need. |
Quoted For Truth |
What's wrong with the good ol' T5, Tony?
Mine isn't bad per se, but it does have it's problems. Increasingly loud whine in 3rd and 5th is starting to worry me. No synchro or shifting problems yet.
I could fix my T5 for cheaper than buying a T56, but the coolness factor of having 6 gears is drawing me in.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Thu Mar 25, 2010 9:38 am Post subject: |
Way over priced. _________________ A redline a day keeps the carbon away! |
Posted: Thu Mar 25, 2010 9:34 pm Post subject: |
| Alphius wrote: | | Xophertony wrote: | | Alphius wrote: | | Dang, I want that. Can't afford it right now though. That's what I need. |
Quoted For Truth |
I could fix my T5 for cheaper than buying a T56, but the coolness factor of having 6 gears is drawing me in.  |
i have not been able to use 5th gear for about three months. i did our entire dyno cruise in fourth. if you get a six speed i'll take your whining 5 speed over mine any day. |
Posted: Fri Mar 26, 2010 1:54 pm Post subject: |
| Xophertony wrote: | | i have not been able to use 5th gear for about three months. i did our entire dyno cruise in fourth. if you get a six speed i'll take your whining 5 speed over mine any day. |
Fun, fun. If I get a 6-speed soon (which I might) I'll sell you my 5-speed for peanuts on the dollar.
It's been whining for over 20k miles and hasn't gotten much worse.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Fri Mar 26, 2010 2:22 pm Post subject: |
| Xophertony wrote: |
i have not been able to use 5th gear for about three months. i did our entire dyno cruise in fourth. |
Whhhhhaaat? _________________
Posted: Fri Mar 26, 2010 10:59 pm Post subject: |
Don't forget this guy is in the market for a manual trans too. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sat Mar 27, 2010 1:36 am Post subject: |
| DBL_TKE wrote: | Don't forget this guy is in the market for a manual trans too. |
i'll sell you mine.  |
Posted: Sun Mar 28, 2010 11:40 pm Post subject: |
...How much  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Mar 29, 2010 7:37 am Post subject: |
| DBL_TKE wrote: | | Don't forget this guy :wavey: is in the market for a manual trans too. |
| Xophertony wrote: | | i have not been able to use 5th gear for about three months. i did our entire dyno cruise in fourth. |
You don't want his "4-speed" T5.
I'll sell you mine! Can I start a bidding war here?  _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Mar 29, 2010 11:07 am Post subject: |
Doesn't matter to me. I'll rebuild either one. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Mar 29, 2010 11:43 am Post subject: |
| DBL_TKE wrote: | | Doesn't matter to me. I'll rebuild either one. |
Oh, gotcha. I'd rebuild mine if I didn't want to get a 6-speed anyway. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Mar 29, 2010 7:02 pm Post subject: |
| Twilightoptics wrote: | | Way over priced. |
Just out of curiosity, what should a decently priced T56 go for? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Mar 29, 2010 8:24 pm Post subject: |
| DBL_TKE wrote: | | Twilightoptics wrote: | | Way over priced. |
Just out of curiosity, what should a decently priced T56 go for? |
Posted: Mon Mar 29, 2010 8:33 pm Post subject: |
| for perspective, I paid $700 for mine, but it needs some rebuilding work. |
