Posted: Mon Mar 08, 2010 8:16 pm Post subject: Horsepower |
I'm thinking we probably should try to move/keep the horsepower replies out of the picture post. Pic post is pretty big as it is. Maybe when shultz comes on he can move them.. Anyway, here's my #s for the 2nd gen.. sad as they are.
237hp/305tq
This is at 4k rpm since my fuel pump can't keep up with my carberator.. Discovered last night that pontiac made 2 different pumps. 1 for a 2 barrell.. which i have.. and one for a 4 barrel. I'm told the 2 barrel pump cannot keep up with a stock 4 barrel.. I've got a bit of a learning curve going on with this poncho motor.
I also have a heat problem causing detonation, Steve stopped my last 2 runs because of this. Possible transmission problems and an intermittant rear brake drag.. when I get these problems solved I expect a few more hp.. maybe with that and a real exhaust I could be pushing 280-300.. I hope!! |
Posted: Mon Mar 08, 2010 8:21 pm Post subject: |
Mine did slightly better this time than last. Might have been the weather No power mods were done to the car, but there was a rear end gear change which should have no effect.
169hp/250tq _________________ 92 Camaro
Posted: Mon Mar 08, 2010 8:30 pm Post subject: |
Weather should be factored in with the correction. I like my uncorrected numbers.. 250hp! lol. |
Posted: Mon Mar 08, 2010 8:42 pm Post subject: Re: Horsepower |
chevymad wrote: | I also have a heat problem causing detonation, |
If you're running out of fuel, isn't it going to ping and get hot regardless though? |
Posted: Mon Mar 08, 2010 8:51 pm Post subject: |
My afr was fine.. til about 4500.. then it went straight up. But amazingly that first run didnt ping. The next 2 after it had warmed up pinged badly. |
Posted: Mon Mar 08, 2010 9:12 pm Post subject: |
chevymad wrote: | Weather should be factored in with the correction. I like my uncorrected numbers.. 250hp! lol. |
Yeah, I figured that, hence the smiley... _________________ 92 Camaro
Posted: Mon Mar 08, 2010 9:55 pm Post subject: |
chevymad wrote: | My afr was fine.. til about 4500.. then it went straight up. But amazingly that first run didnt ping. The next 2 after it had warmed up pinged badly. |
Ahh... somehow I was thinking you were lean throughout.
Just for S&G's I overlayed the Monterey's runs with the IROC's runs from last year. The similarity of the HP curve is shocking. The only real difference is that it just keeps going, instead of the TPI nosedive.
The problem with the Monterey is illustrated pretty clearly in the lower panel, however.
Posted: Mon Mar 08, 2010 11:33 pm Post subject: |
RSFreak wrote: | What RPM was the peak hp and tq at? |
283hp @ ~5250
316tq @ ~4000
I want moooorrreee powah!!
I noticed the bird has 290lb/ft tq @ 1900rpm. I like torque tables. _________________
GREG DAVIDSON Member
Posted: Mon Mar 08, 2010 11:45 pm Post subject: |
I need ALOT more power in my Daytona 130.64 hp and 162.73 tq i need more boooooost ! |
Posted: Tue Mar 09, 2010 7:42 am Post subject: |
If it looks like a boat, and smells like a Yamaha outboard it must be...... A Monterey!
Mazda made:
111 HP
108 LB/FT
Up 23 from last years 88hp for a 26% increase! AND she's a full point lean at 13.5:1. Time to research how much to jet up!
And until my 4th run which was 5th gear top speed, it put out less smoke with an Oil Injection System! LOL Than most of the SBC! _________________ A redline a day keeps the carbon away! |
Posted: Tue Mar 09, 2010 9:03 am Post subject: |
I think my oil injection system was malfunctioning. |
Posted: Tue Mar 09, 2010 9:36 am Post subject: |
iansane wrote: | I think my oil injection system was malfunctioning. |
Lube the tube! _________________ A redline a day keeps the carbon away! |
fiveoformula Member
Posted: Tue Mar 09, 2010 12:17 pm Post subject: |
The Formula oiled down the pipes with 158HP and 252LB FT. Quite a bit better than the 129HP run last year as I corrected the lean condition. It was Pig rich this time. _________________
'88 FORMULA |
Posted: Tue Mar 09, 2010 12:51 pm Post subject: |
fiveoformula wrote: | The Formula oiled down the pipes with 158HP and 252LB FT. Quite a bit better than the 129HP run last year as I corrected the lean condition. It was Pig rich this time. |
What were your AFRs? Time for N20? |
Posted: Tue Mar 09, 2010 5:45 pm Post subject: |
Hehe... Derrick's AFR had a big ol' hole in it.
Although since you have a high-mileage TBI 305, by crew logic you should put a gianourmous shot on it and be fine for years to come. |
Posted: Tue Mar 09, 2010 7:36 pm Post subject: |
fiveoformula wrote: | ...and 3 more horses than Skyler! |
Reeaal mature, Derek. Real mature... _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Tue Mar 09, 2010 11:50 pm Post subject: |
Can't wait to get my T/A on the dyno next year! _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
fiveoformula Member
Posted: Wed Mar 10, 2010 9:22 am Post subject: |
aaron_sK wrote: | Hehe... Derrick's AFR had a big ol' hole in it.
Hehe I think it's time!
The AFR's were like 10.3 all the way thru, but it had a wierd dip at about 4500rpm. |
Kyleneon New Member
Joined: 05 Feb 2010 Posts: 11 Location: Hilsburrito, OR
1999 Chevrolet Camaro
Posted: Wed Mar 10, 2010 10:32 am Post subject: |
the little red ricer made
279
345
better then last years 260 with the dam over boost protection!! _________________ 99' Neon R/t boosted 300+rwhp |
Posted: Wed Mar 10, 2010 10:47 am Post subject: |
GREG DAVIDSON wrote: | I need ALOT more power in my Daytona 130.64 hp and 162.73 tq i need more boooooost ! |
No.... You need less boost or more fuel to get you out of the dangerous 14+:1 Ratio.
Think about it: Mopar 2.2L Turbo starting in 1984:
"Chrysler used a Garrett Research T-3 turbocharger, including an integral wastegate, with a maximum boost of 7.2 psi;"
Not 14. And not your 11psi. They cranked the boost without adding fuel. Good thing your motor is tired, all the boost pressure is just passing the rings and not blowing up!
What to know about your motor:
http://www.allpar.com/mopar/22t.html _________________ A redline a day keeps the carbon away! |
