Wolffy Member
Posted: Wed Jan 05, 2005 10:55 pm Post subject: need black interior pieces |
I am looking for the foot kick panels (i think, need to check my stash in the am)
the rear quarter panels, i do not want pieces that have the hole for the pull over trunk thingy
and the center trunk piece |
Midnight Sun Member
Posted: Thu Jan 06, 2005 9:17 am Post subject: |
May I suggest krylon fusion paint.
I used it to change my interior panels from tan to black. And it worked far better then I expected.
But, a lot of people have far higher standards than myself. _________________
Wolffy Member
Posted: Thu Jan 06, 2005 12:03 pm Post subject: |
if its works & looks good, why not ?
ill look into that, thanxs |
Posted: Thu Jan 06, 2005 12:57 pm Post subject: |
I used a spendy system from the local paint shop that had a soap,cleaner spray, prep spray, and paint.... scuffing with a scotchbite too.
Seemed to work pretty well, did the arm rest in my old jimmy along with the rest of the trim, and that arm rest stayed black!
Why not get the hatch pull down? They are sweet to have to cover your stuff in the back. |
Wolffy Member
Posted: Thu Jan 06, 2005 4:40 pm Post subject: |
| cause im going to build a box for my T-Tops & speakers (when i can get them someday) |
Posted: Thu Jan 06, 2005 7:13 pm Post subject: |
| Wolfy's_88IrocZ28 wrote: | | cause im going to build a box for my T-Tops & speakers (when i can get them someday) |
if you have the flat panel style box for speakers, you can put the t-tops right ontop. Just get the grills for the subs. Mike has it like that, Dewey has it like that, and I kinda have it like that. Then it's all covered by the pullover. |
