somethin is going on...fuel pump maybe?
91camaro_rs
PostPosted: Sun Feb 21, 2010 7:55 pm    Post subject: somethin is going on...fuel pump maybe? Reply with quote
ok so today i came to a stop sign and the car died, it did that twice. and also when i slow down to go around a corner then give it gas, it takes like a second then the throttle will respond, its a long gap, and it just started doing this, could it be the fuel pump? i have a new filter and injectors
PostPosted: Sun Feb 21, 2010 8:06 pm    Post subject: Reply with quote
Get a gauge off of Summit. Dry, not the liquid filled ones. Take the schrader valve off of your rail (relieve the pressure first).
Take both of them down to Wofsco on Puyallup Ave. Tell whoever is working the plumbing desk that you want an L and adapters to make an elbow to fit the gauge on your rail. Fittings will be like three bucks, gauge will be like 25 shipped.
PostPosted: Sun Feb 21, 2010 8:20 pm    Post subject: Reply with quote
I don't think TBI has a schrader valve, think you have to hook into the line. My guage kit has an adapter to do this.
PostPosted: Sun Feb 21, 2010 8:25 pm    Post subject: Reply with quote
I don't think so either. Doesn't matter since he's got a 3.1, though. Razz
91camaro_rs
PostPosted: Sun Feb 21, 2010 8:35 pm    Post subject: Reply with quote
lol believe me my car has a schrader valve, that thing sprayed gas in my face once when i was putting the new injectors in
PostPosted: Sun Feb 21, 2010 9:34 pm    Post subject: Reply with quote
Embarassed
I'll be over here minding my own business. Laughing
91camaro_rs
PostPosted: Mon Feb 22, 2010 12:18 pm    Post subject: Reply with quote
is there any way to tell without buying a guage? or does anyone have one i can borrow? kinda on a tight budget, also my car gave me codes 32 and 15 today
32-egr failure
15- Coolant Temp Sensor
i just replaced that sensor why would it be throwin a code, or would not mixing the coolant right effect it like having more water than AF making the temp get higher?
PostPosted: Mon Feb 22, 2010 12:29 pm    Post subject: Reply with quote
I have a gauge you're welcome to use.
How's your connection on the CTS? If you get that fixed, then your EGR code may also go away.
PostPosted: Mon Feb 22, 2010 1:00 pm    Post subject: Reply with quote
The CTS on a 3.1 will cause it to stall.
I have had the EGR fail and cause stalling too, but its like 200bux to fix the right way.
Start at the 20bux CTS.
PostPosted: Mon Feb 22, 2010 3:03 pm    Post subject: Reply with quote
I've got a gauge as well. Do you have an obd cable to read what the computer sees for the CTS?
91camaro_rs
PostPosted: Mon Feb 22, 2010 4:04 pm    Post subject: Reply with quote
ok i might need to borrow the guage, and no OBD i just used the engine light blinky method and it said code 15 chilton says CTS (temp LO)
i just replaced that sensor too...
PostPosted: Mon Feb 22, 2010 5:55 pm    Post subject: Reply with quote
I had terminal ends come loose and get damaged on me before. Different sensor, but it cause problems.
PostPosted: Mon Feb 22, 2010 6:08 pm    Post subject: Reply with quote
How recent was it replaced? The unit might be DOA, the plug might be loose as Jay mentioned, or you might have been sold the wrong part.
Also, a ratio favoring water over antifreeze will cause the engine to run cooler, not hotter. That is until it hits 215* or 32*. Razz
^ Science
91camaro_rs
PostPosted: Mon Feb 22, 2010 10:54 pm    Post subject: Reply with quote
replaced the sensor when my timing chain went out, which was about when i got those manifold bolts from you.
car stalled twice today at a stop when i went to give it gas, and it sounds like the fan is coming on way earlier than it should
