Dyno curse, who's it got???
PostPosted: Thu Feb 18, 2010 7:36 pm    Post subject: Dyno curse, who's it got??? Reply with quote
Who's it got this year? Even though I haven't decided to put my car on the rollers, or even which car to bring, my 89 sort of broke down this morning.
While waiting for our driver at the Park-n-Ride where we meet, I noticed some liquid meandering from under the car, but was still too dark to see where it was coming from. My first guess was water pump. On the way home, I let it get up to temperature, then pulled off into a service station and opened the hood to find water slinging off the water pump pulley. I suppose the shaft seal is shot.
I've always wondered when it might go. It looks to be original as does the timing cover, even after 200,000 miles Smile Looks like part of a long vacation weekend will be spent under the car Laughing
PostPosted: Thu Feb 18, 2010 7:45 pm    Post subject: Reply with quote
Well as of right now the Camaro has oil pressure AND runs through the gears without a hitch from the motor.
Mazda seems to be working well with the new header/modified intake.
We shall see. I think money will be my curse.
PostPosted: Thu Feb 18, 2010 8:13 pm    Post subject: Reply with quote
I hear Paul on the money thing. Barring anything drastic I think i'm good to go. But I've got alot of small things to fix, and you know how that is.. all it takes is time and money!
No leaks or anything under the car tonight. Still holding good oil pressure and running cool... fingers are crossed!
PostPosted: Thu Feb 18, 2010 9:27 pm    Post subject: Reply with quote
I have nothing wrong so far but I'm crossing my fingers, knocking on wood and praying. Laughing
d00012
PostPosted: Thu Feb 18, 2010 11:06 pm    Post subject: Reply with quote
No job soon enough...firebird is grounded. Crying or Very sad
I probably will make it in my Camaro, but doubt I will run it on the dyno.
PostPosted: Fri Feb 19, 2010 1:05 am    Post subject: Reply with quote
My red car was totaled and the alternator just blew in my blue car....
Does either one of those count??
-Donald
PostPosted: Fri Feb 19, 2010 1:49 pm    Post subject: Reply with quote
New pump is in. Waiting now for the RTV to set up on the gaskets. There was nothing left of the seal on the old one the way it sounded when I spun the shaft.
PostPosted: Fri Feb 19, 2010 4:01 pm    Post subject: Reply with quote
Shocked
PostPosted: Fri Feb 19, 2010 6:11 pm    Post subject: Reply with quote
Shocked
Hehe.. more goo is good isnt it?? Very Happy
PostPosted: Fri Feb 19, 2010 7:56 pm    Post subject: Reply with quote
chevymad wrote:
Shocked
I didn't use a whole lot of it. Maybe a little more than necessary to hold the gaskets in place while installing the pump. I used that black stuff in the cheese whiz can, applying the most at the outside edge of the gasket and around the bolt holes
PostPosted: Fri Feb 19, 2010 8:02 pm    Post subject: Reply with quote
Myself, I usually glue the gasket to the pump, then use a thin layer between the gasket and the engine. That way when I go to remove it the gasket stays with the old pump and its easier for me to clean.
90% of the gaskets on an engine should be either just glued on, or put on dry. The only normal places for the stuff in a tube is the china walls, and anywhere where 2 gaskets meet. Or if something is pitted really bad. I think Paul's shock smiley is because as a mechanic we see lots of do it yourselfers using tons of goo where they shouldnt be using any.
Mostly we're giving you a hard time. Very Happy
PostPosted: Fri Feb 19, 2010 8:07 pm    Post subject: Reply with quote
I kinda had that figured out already Cool
PostPosted: Fri Feb 19, 2010 8:10 pm    Post subject: Reply with quote
Pffft. If a thin layer is good, then a thick layer is great, right? ...Right?
PostPosted: Fri Feb 19, 2010 8:12 pm    Post subject: Reply with quote
Donald, does that mean you're coming to Dyno with the blue car?!
PostPosted: Wed Feb 24, 2010 2:42 pm    Post subject: Reply with quote
yep! with a squeaky new alternator!
(it randomly squeaks really really loud Sad )
-Donald
PostPosted: Wed Feb 24, 2010 5:24 pm    Post subject: Reply with quote
Return it!
Then tell them you changed your mind and you wanted a 12si instead. Razz
PostPosted: Wed Feb 24, 2010 8:19 pm    Post subject: Reply with quote
Well throw me into the loop!
I am having the upholstery done in the Shark, started great, then POW the fabric I choose was almost a week late coming in, the leather showed as scheduled.
Then the dude doing the work has been out with the flu Shocked
When it comes to interior...NO RUSHING IT! Laughing
PostPosted: Wed Feb 24, 2010 8:34 pm    Post subject: Reply with quote
Lawnchair. Zip ties. Problem solved.
PostPosted: Wed Feb 24, 2010 10:09 pm    Post subject: Reply with quote
Laughing Laughing Laughing
PostPosted: Thu Feb 25, 2010 8:47 am    Post subject: Reply with quote
I had a nightmare about dyno curse last night. It was horrible. Everything kept going wrong. Laughing
Been daily driving the Camaro for a week or two to flush out any bugs before the big weekend, and it's been running flawlessly so far... *knock on wood*
