Tune up
kutison
PostPosted: Wed Feb 10, 2010 11:05 am    Post subject: Tune up Reply with quote
I know this is a stupid question, but what is everything covered in a tune up, and is it worth the time to do it myself, keeping in mind I don't have a garage or access to a jack.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
TurdGen1989
PostPosted: Wed Feb 10, 2010 11:09 am    Post subject: Re: Tune up Reply with quote
cap
wires
plugs
oil change
maybe check your air filter to?
its definitely worth it to do your self because then you get to work on your car Very Happy
do the plugs only if you can fit under your car without a jack... because 7-8 are a PITA without getting under the car.
thats usually what i do feel free to add peeps! lol
Phil.
GMC High Sierra
kutison
PostPosted: Wed Feb 10, 2010 11:09 am    Post subject: Reply with quote
I meant to put this in the garage.
I'm fairly sure I know everything that gets replaced, I just don't wanna miss anything.
PostPosted: Wed Feb 10, 2010 11:49 am    Post subject: Reply with quote
-Fuel filter
-Clean throttlebody
-PCV valve
-And Vacuum lines that are ugly/cracking
-Spark Plugs
-Spark Plug Wires
-Distributor Cap
-Distributor Rotor
-Air Filter
d00012
PostPosted: Wed Feb 10, 2010 1:26 pm    Post subject: Reply with quote
Oil filter
Maybe even a little Seafoam. That's woken up a few vehicles of mine from time to time.
PostPosted: Wed Feb 10, 2010 2:16 pm    Post subject: Reply with quote
The only thing you need a jack and stands for are the oil and fuel filters, and the front end lube.
You can a cheapo jack and a set of stands at Schmucks or something for like $50.
When you do the work yourself, not only are you saving money, but you are getting better parts... assuming you buy better parts. Razz
Personally I prefer a job done with Wix filters, Royal Purple oil, Autolite plugs, Blue Streak cap & rotor, Taylor wires. You get the idea.
d00012
PostPosted: Wed Feb 10, 2010 2:24 pm    Post subject: Reply with quote
Autolites and Taylor wires are next on my list.
PostPosted: Wed Feb 10, 2010 8:31 pm    Post subject: Reply with quote
Lets not forget checking/replacing all fluids. Wink
d00012
PostPosted: Wed Feb 10, 2010 8:33 pm    Post subject: Reply with quote
Most importantly...headlight fluid and elbow grease. Very Happy
I know, I'm lame...
On a serious note, check all your sensors, too.
kutison
PostPosted: Thu Feb 11, 2010 6:44 am    Post subject: Reply with quote
gotcha, headlight fluid for the break lights and elbow grease for the injectors. that spray pattern was looking to fine, I think it makes the car look cooler when they drip.
Oil change was done 400 miles ago but the car does deserve royal purple, o2 sensor was done recently PCV valve and air filter.
Playin with the cap in rotor should be fun for my back (not old, just fat)
won't I need a jack for the fuel filter?
d00012
PostPosted: Thu Feb 11, 2010 10:08 am    Post subject: Reply with quote
I didn't, but that's because I have the sport coupe, no side skirts on mine.
PostPosted: Thu Feb 11, 2010 11:02 am    Post subject: Reply with quote
