Posted: Wed Jan 27, 2010 11:02 pm Post subject: |
Make sure if you need hub centric that they are!
I bought some for the Mazda. They wanted make/model/year and what I was going to convert to.
Mazda has hubcentric wheels. Spacers came... they built them lug centric. Shook like a dog shittin' peach pits. I had to machine spacers to center the adapters AND the new wheel. Wasn't fun. _________________ A redline a day keeps the carbon away! |
Posted: Wed Jan 27, 2010 11:09 pm Post subject: |
| Twilightoptics wrote: | | Make sure if you need hub centric that they are! |
Come to think of it, that truck is hub centric.
Thanks for the heads up, Paul. |
Leejo2005 Member
Posted: Thu Jan 28, 2010 8:35 am Post subject: |
| Twilightoptics wrote: | | Shook like a dog shittin' peach pits. |
Classic. |
Posted: Sat Jan 30, 2010 7:23 pm Post subject: |
I saw a bunch of cheap wheel spacers online and got scared. Ended up spending the extra doh and getting the H&R's. Real nice though. SOLID and hug centric. The cheapies looked like they were cast and were missing some metal. Plus this way I can go to the place I got them instead of dealing with an online company.
Lol, huge difference there man. _________________ E30
Posted: Sun Jan 31, 2010 2:44 pm Post subject: |
I bought mine through an eBay seller. They did not, however, have the correct center bore. I had to dremel them out to get them to fit, tightly at that. I'll update later with which seller it was. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sun Jan 31, 2010 5:39 pm Post subject: |
Bought mine from ebay years ago. They were cheap. Something like $75 for all four? Fit fine and have taken some pretty hefty abuse.  _________________
Posted: Sun Jan 31, 2010 9:09 pm Post subject: |
Ian, I was gonna go with VBP (Vette Brakes and Products) spacers for my Z06 wheels as thats what I know a bunch of guys on TGO are using. Do you know who made your Ebay ones? _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Mon Feb 01, 2010 12:41 am Post subject: |
I bought mine here. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Feb 01, 2010 8:32 am Post subject: |
Hmm... those are the same ones I ended up buying...
Guess I'll really have to remember to retorque before I hit the freeway. |
Posted: Wed Apr 07, 2010 3:21 pm Post subject: |
I thought the centerbore for 3rd gens is 70.5mm? Those say they're 78.3. Can anyone verify which is correct? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Apr 07, 2010 4:40 pm Post subject: |
Talking the Hub size? It's pretty standard for 4 3/4 on 5 patterns. Vettes are the same. _________________ A redline a day keeps the carbon away! |
Posted: Fri Apr 09, 2010 2:11 pm Post subject: |
Well I just bought the same ones Ian did. I hope these work out a little better than my last set. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Apr 09, 2010 2:12 pm Post subject: |
Re-torque them per spec. Then re-torque them again.
They don't "fail" by having the lugnuts unscrew. That's your beans!  _________________ A redline a day keeps the carbon away! |
Posted: Fri Apr 09, 2010 4:01 pm Post subject: |
| Twilightoptics wrote: | Re-torque them per spec. Then re-torque them again.
They don't "fail" by having the lugnuts unscrew. That's your beans!  |
I never said mine "failed," the center bore on my last set was too small to even put the adapter on. I had to expand the bore in order to even mount them. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Apr 09, 2010 4:22 pm Post subject: |
| DBL_TKE wrote: | | Well I just bought the same ones Ian did. I hope these work out a little better than my last set. |
Careful, this time your whole car will end up in the bushes.  |
Posted: Fri Apr 09, 2010 7:20 pm Post subject: |
| iansane wrote: | | DBL_TKE wrote: | | Well I just bought the same ones Ian did. I hope these work out a little better than my last set. |
Hey! zip it ::knock on wood::  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
