lostinconformiti Member
Joined: 18 May 2008 Posts: 146 Location: Vancouver,Wa
Posted: Sun Nov 15, 2009 3:40 pm Post subject: i need heat |
and by heat i mean defrost at least so i can see while im driving and its cold, can anyone help me rewire my heater controls this week? im not getting any power to my blower motor. anything helps thanks guys. _________________ "this thread is worthless with out pictures"
new all time favorite quote. |
Posted: Tue Nov 17, 2009 8:05 pm Post subject: |
Got this figured out yet? I might be down that way this weekend to pick up a pair of seats, if so, maybe I could lend a hand. _________________ 92 Camaro
Posted: Sat Nov 28, 2009 11:14 am Post subject: |
sadly i still dont, and its getting colder and colder, ive just been so busy now that i work 2 jobs, that i just havent had the time. hoping to get it figured out this week. i just need to figure out where it goes from after the plastic block piece, because my blower has no power at all. motor, resistor, and relay are all new. it worked last year but i had to futs with the wire a bit to get it to work the first time. this year i have no luck. _________________ "this thread is worthless with out pictures"
Posted: Sat Nov 28, 2009 11:24 am Post subject: |
Bad ground? Bad switch? |
Posted: Sat Nov 28, 2009 12:00 pm Post subject: |
Al Hasse wrote: | Bad ground? Bad switch? |
Switch may have melted. Seen that one before. Also, by resistor you mean rheostat, correct? |
Posted: Sat Nov 28, 2009 12:23 pm Post subject: |
aaron_sK wrote: | Al Hasse wrote: | Bad ground? Bad switch? |
There is a resistor inside the heaterbox. 3 different windings for 3 different speeds. _________________ A redline a day keeps the carbon away! |
Posted: Sat Nov 28, 2009 12:31 pm Post subject: |
If that "resistor" is bad, then high speed should still work, it's for the lower speeds. Possible it could kill all speeds. |
bAd DaWg 85 Z28 Member
Joined: 14 Jan 2004 Posts: 157 Location: Taking up space
Posted: Sat Nov 28, 2009 12:36 pm Post subject: |
Happend to mind two winters back and it was the switch so look there first. _________________ If ya can't fixit F#ck IT!!!!!!.........
DaWg
85 Z28
65 Chevy sport truck
85 K20 4x4 truck |
Posted: Sat Nov 28, 2009 1:08 pm Post subject: |
Twilightoptics wrote: | There is a resistor inside the heaterbox. 3 different windings for 3 different speeds. |
For some reason I was thinking of the three-coil resistor as a rheostat. Must be all that crack I smoked for breakfast this morning. |
Posted: Sat Nov 28, 2009 1:20 pm Post subject: |
I'd suggest the switch. I replaced mine last year when I lost high speed. I pulled it out and half of it was melted away!
GM part # 16068778 for a four speed switch. ~$13 _________________
Posted: Tue Dec 01, 2009 5:05 am Post subject: |
lol i guess this is what i get for not checking this. lol havent checked the switch but now i have a just as bad problem stupid turn signal lever broke off in the column (stupid niehoff products) i have to fix that first. or at the same time... oh and i have NO SPEEDS. i never have heat. like at all. lol _________________ "this thread is worthless with out pictures"
Posted: Tue Dec 01, 2009 6:58 am Post subject: |
The signal lever pulls straight out of the column, as long as the wipers are off. (learned that one the hard way before Brandon set me straight )
If you can get ahold of any piece of it with vise grips, just yank it out. Five dollar JY part.
Checking the heater switch takes one minute. Pull the four T-15 screws out of the trim around the radio/HVAC. Remove the three 7mm screws holding the HVAC control itself. Pull it forward, and look for meltyness. |
Posted: Wed Dec 02, 2009 1:42 pm Post subject: |
ya this is the second one thats broken off in the column but the first one was the stock one and was bent in the column so i learned how to take them out from that one. this time though im getting one from a JY this replicas are so crappy.
im going to check for meltyness right now BTW. _________________ "this thread is worthless with out pictures"
Posted: Wed Dec 02, 2009 2:16 pm Post subject: |
so i see no meltyness. here are pics, _________________ "this thread is worthless with out pictures"
Posted: Wed Dec 02, 2009 4:16 pm Post subject: |
The connector on the far left in each picture, pull that off. In the bottom shot you can see some buring/brittleness. |
Posted: Wed Dec 02, 2009 5:14 pm Post subject: |
Posted: Thu Dec 03, 2009 1:59 am Post subject: |
wow i didnt even notice that. i guess i have to thank my phone for that awesome pic. lol is there any way to be 100 percent that its the switch? _________________ "this thread is worthless with out pictures"
TurdGen1989 Member
Posted: Thu Dec 03, 2009 6:14 am Post subject: |
dunna dun dunna dun trooooogdoooorrr _________________ Phil.
GMC High Sierra
Posted: Thu Dec 03, 2009 9:00 am Post subject: |
lostinconformiti wrote: | wow i didnt even notice that. i guess i have to thank my phone for that awesome pic. lol is there any way to be 100 percent that its the switch? |
Buy a new switch for three bucks at the junkyard. Replace. Turn on heater. Drink beer.
Or you can get out your multimeter, pull the plug off, and test the resistance of the hot lead to the three lines going to the resistor. |
Posted: Sat Dec 05, 2009 5:09 pm Post subject: |
with work i havent been able to get out to the JY but i have tuesday off luckily, so i should be able to work on her then. and hopefully ill have heat again _________________ "this thread is worthless with out pictures"
