lostinconformiti Member
Joined: 18 May 2008 Posts: 146 Location: Vancouver,Wa
Posted: Tue Sep 15, 2009 12:26 am Post subject: Power Steering pump |
| so my power steering pump is leaking, which is the smarter choice, Reman'd pump or a rebuild kit? i already have the rebuild kit, it came with the car but i haven't really heard of anyone rebuilding a power steering pump. what do you guys think, rebuild or replace? |
Posted: Tue Sep 15, 2009 6:49 am Post subject: |
Make sure it's the pump and not the fittings of the lines.
Remaned pump is 100 times easier.
Buy a new $20 feed line while you're at it. _________________ A redline a day keeps the carbon away! |
alloy T56 Elitist
Posted: Tue Sep 15, 2009 9:51 am Post subject: |
Don't forget to replace the return line also. It's just bulk power steering hose with worm drive clamps to secure it since it's low pressure.
We had a flyer on PS pumps and 70% of the time pump failure was due to the hoses breaking down and contaminating the pump.
You will need to remove the pulley from the old pump and press it on the new one. Make sure you use the special PS pump pulley remover and installer or you will break the pulley if you use a 3 jaw puller on it. The parts store should have one for rent. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
Posted: Wed Sep 16, 2009 1:26 pm Post subject: |
| well i think its the feed line, since its leaking from the back down the high pressure line. found that out today. |
alloy T56 Elitist
Posted: Wed Sep 16, 2009 2:33 pm Post subject: |
It usually is the high pressure line that goes first, but if the pressure line is deteriorated enough to leak, the return line is the same age as the pressure line is, so a few $$$ to replace the return is money well spent. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
dlp Member
1990 Chevrolet Camaro IROC-Z
Posted: Wed Sep 16, 2009 7:31 pm Post subject: |
| I replaced the PS pump a couple of weeks ago on my wifes 90 convertible. I bought a remanufactured pump without a resevour from NAPA for about 55.00 bucks. You wouldnt think a rebuild kit would be much cheaper than that. |
Posted: Wed Sep 16, 2009 8:07 pm Post subject: |
Try replacing the lines first. Takes about two minutes if you don't have AC. Little bit more work if you do.
I've never seen the pump itself leak. Leaks usually come from the pitman arm seal, or the line seals. |
Posted: Fri Sep 18, 2009 11:19 pm Post subject: |
| so im going to replace the lines tomorrow.... in the parking lot of an apartment complex.... that should be fun.... i can get beer if anyone has an open driveway in vancouver/portland. oh and my compressor for the ac is still there but my lines are gone (have been since before i owned the car) is it safe to just pull the compressor out? car has the v-belt system not the serp setup. |
Posted: Sat Sep 19, 2009 9:26 am Post subject: |
You can pull the compressor off if you'd like. Free up that 2hp from losing one belt too! _________________ A redline a day keeps the carbon away! |
Posted: Sat Sep 19, 2009 2:01 pm Post subject: |
| alright cool im going to buy the high pressure line right now. |
