Belt tensioner for serp V6
PostPosted: Tue Sep 15, 2009 9:18 pm    Post subject: Belt tensioner for serp V6 Reply with quote
Non-squeaky if at all possible. Mine is starting to get annoying. I believe they are specific to the V6 cars.
Thanks.
PostPosted: Tue Sep 15, 2009 9:35 pm    Post subject: Reply with quote
Just the pulley or the whole assembly. NAPA has both for the 2.8 and 3.1.
It's pricey, the assembly goes for about $65 and just the pulley goes for about $32. It's about the only way I could find one for mine when the thing broke.
PostPosted: Wed Sep 16, 2009 8:16 pm    Post subject: Reply with quote
Yup yup Yup. That's why I want a used one. Mine is a junkyard special. I;d buy another one there, but the Camaros are picked over like you would not believe.
PostPosted: Wed Sep 16, 2009 10:26 pm    Post subject: Reply with quote
I'm not sure what that particular pulley looks like, but I've replaced the bearings in about 5 pulleys on different vehicles so far. Pressed it out and got the bearing number and went to Bearings Inc and got a new one for under $10.
Take a look at it, might be the best way to go if you can get the bearing out.
PostPosted: Thu Sep 17, 2009 6:28 am    Post subject: Reply with quote
If you do that check out Mcguire Bearing Company on center street right below Yakima. Inexpensive and decent quality. I've gotten a couple oddball bearings there.
PostPosted: Thu Sep 17, 2009 7:07 am    Post subject: Reply with quote
I might have one laying around. If so, its yours for free. Will try to rem to look tonight.
3.1 motor correct?
PostPosted: Thu Sep 17, 2009 10:12 am    Post subject: Reply with quote
2.8 and 3.1 use the same serp belt tensioner.
PostPosted: Thu Sep 17, 2009 11:14 am    Post subject: Reply with quote
cool, didnt know that.
PostPosted: Thu Sep 17, 2009 3:55 pm    Post subject: Reply with quote
Still have it. You want it, or wanting to get one local?
kurfbird
PostPosted: Fri Sep 18, 2009 7:01 pm    Post subject: belt tensioner Reply with quote
I have one from a 3.1 bird. LMK if your interested.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Fri Sep 18, 2009 7:11 pm    Post subject: Reply with quote
Jay's is already on the way. Sorry, Bruce.
kurfbird
PostPosted: Fri Sep 18, 2009 7:17 pm    Post subject: No problem Reply with quote
No problem
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
