posi or not?
PostPosted: Sat Aug 22, 2009 12:50 pm    Post subject: posi or not? Reply with quote
do i got a posi?
that is the question.
i got a 1987 firebird trans am, 305 v8 tpi, stock i think.
i did a little burn out and there was two lines but they were both pretty light (i don't wanna waste my fairly new tires)
when its off the ground, and i spin one, they both turn in the same direction, but i can move the passengers side and have the drivers side stay still.?
-Donald
PostPosted: Sun Aug 23, 2009 3:28 pm    Post subject: Reply with quote
ok, does this pic help?
there is two lines there....?
-Donald
PostPosted: Sun Aug 23, 2009 5:30 pm    Post subject: Reply with quote
sometimes with a sudden drivetrain shock, (like dumping the clutch) you can get the spider gears to shock and move in sync with the ring gear. usually it only happens for a second or two, but there's freak incidences where it can go on for longer.
well...at least that's the way I've understood it...perhaps someone can correct this if its untrue?
that being said, I'd check your RPO codes and see if you have the G80 code on the build sheet. if you don't, its pretty safe to say you have an open diff.
PostPosted: Sun Aug 23, 2009 5:59 pm    Post subject: Reply with quote
Even if he did have a limited from the factory, theres no guarantee that it's still in there, or that it works.
Doing a donut is not a good indicator of your rearend. Your tires are spinning because the suspension is being loaded and unloaded from side to side. Brakestand it just for a bit and see what happens.
PostPosted: Sun Aug 23, 2009 6:16 pm    Post subject: Reply with quote
That doesn't even work, if you have equal traction loss, both wheels will spin.
Both tires turning the same direction is a good indication that it is a posi. But, the ONLY way to tell for sure, is to just pull the rear cover, and look.
PostPosted: Sun Aug 23, 2009 7:18 pm    Post subject: Reply with quote
This is true. However for the cost of fluid and expenditure of time, I have found a straight-line mild brakestand to be a fairly accurate and mildly entertaining indicator. Very Happy
PostPosted: Sun Aug 23, 2009 8:10 pm    Post subject: Reply with quote
Jack the car up on the pumpkin, in Neutral, turn one wheel. If the other spins in the same direction it's a posi. If it doesn't spin, or it spins in the opposite direction is an open or a worn out posi.
Those look like Posi marks to me.
91camaro_rs
PostPosted: Sun Aug 23, 2009 8:36 pm    Post subject: Reply with quote
idk if this helps determine if its a posi or not but here is a lil vid from today
http://www.youtube.com/watch?v=4Tb35o-GVPw
PostPosted: Sun Aug 23, 2009 9:45 pm    Post subject: Reply with quote
Unless its a Zexel/torsen! Laughing Always an exception to the rule. My torsen acts completely like an open diff when the rear end is jacked up.
Of course unless he has a 4th gen rear, its not likely he has a zexel either.
PostPosted: Sun Aug 23, 2009 9:59 pm    Post subject: Reply with quote
they spin in the same direction, but i was able to spin the passengers side with the drivers side staying still....
worn out posi seems like it could be a match!
and i could not find my RPO list, Sad
-Donald
