Posted: Thu Aug 13, 2009 6:31 pm Post subject: I picked up some Camaro SS wheels |
I bought some more goodies for my car . I'll post pics later tonight when I pick em up.
::Cue peanut gallary... now:: _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Thu Aug 13, 2009 7:42 pm Post subject: |
Isnt your sig long enough already?  |
Posted: Thu Aug 13, 2009 10:54 pm Post subject: |
Camaro SS wheels They aren't in the best condition. They will need to be repainted. One tire has a nasty gash in the side wall and another has a chunk missing from the shoulder which I don't think would be safe to drive on. The wheels are 17x9" and the tires that came on them are 285/40/17 Nitto NT555's. At least two of them are decent with a little tread on them.
What was funny is that a couple of days ago I made up my mind that I wanted to get some different wheels and SS wheels were near the top of the list, so I hopped on Craigslist to see if anyone was parting out any cars and BAM! the first listing was for some SS wheels for $200. Talk about good timing.
There is some curb rash and a couple iffy slight bends in the outer lip so hopefully they all hold air. If so, then I'll be one happy camper. If they don't, I just found out one my friends has a couple sets of SS wheels so I wont be SOL. Either way I think They'll compliment my Ground Control kit nicely. I was also thinking of painting these either gunmetal, silver or satin black. What do you think?
fiveoformula Member
Posted: Thu Aug 13, 2009 11:45 pm Post subject: |
I think those in satin black would look really good, but on a blue car I'd probably do a lighter color. Nice find!  _________________
'88 FORMULA |
Posted: Fri Aug 14, 2009 8:53 am Post subject: |
| fiveoformula wrote: | I think those in satin black would look really good, but on a blue car I'd probably do a lighter color. Nice find!  |
+1. If you go black on those, you'd have to have some lighter accent on the wheel, like the outer rim, or maybe the face of the spokes.
Solid black on your near-black car would look murdered out IMHO. |
dlp Member
1990 Chevrolet Camaro IROC-Z
Posted: Fri Aug 14, 2009 7:52 pm Post subject: |
| Gun metal grey would look good, or polish them. 200.00 bucks was a good deal. |
Posted: Fri Aug 14, 2009 9:06 pm Post subject: |
Awesome! Those will look great on your car. I just picked up some SS wheels I'm thinking about rocking for awhile. _________________
Posted: Sun Aug 16, 2009 12:04 pm Post subject: |
| iansane wrote: | | Awesome! Those will look great on your car. I just picked up some SS wheels I'm thinking about rocking for awhile. |
Will they fit over your brakes?!?!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun Aug 16, 2009 7:24 pm Post subject: |
| RSFreak wrote: | | iansane wrote: | | Awesome! Those will look great on your car. I just picked up some SS wheels I'm thinking about rocking for awhile. |
Will they fit over your brakes?!?!  |
They're from a different year SS.  _________________
Posted: Sun Aug 16, 2009 7:55 pm Post subject: |
| iansane wrote: | | RSFreak wrote: | | iansane wrote: | | Awesome! Those will look great on your car. I just picked up some SS wheels I'm thinking about rocking for awhile. |
They're from a different year SS.  |
Ahhhhh! 5thgen perhaps?!?!  |
Posted: Sun Aug 16, 2009 11:53 pm Post subject: |
After some searching, 285/40/17 tires up front are going to be a bit iffy, especially when lowered. I'm going to roll all my fenders but does anyone have any thoughts on what size spacers I should run up front? I really like the look of flush wheels but I don't want to rub like crazy. I've heard of people running 2" or 2.25" adapters. I'm sure I'll have to BFH the inside wheel wheel a bit but what else should I be concerned about? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Aug 17, 2009 12:25 am Post subject: |
| I'm running 2" fronts on my car, but with my brakes, it sicks them out an extra 1/8", but your wheels are also wider. I think up front, larger than 2" is going to stick those wheels out too far. |
90droptoproc Member
Posted: Mon Aug 17, 2009 2:58 am Post subject: |
why not mock them up on the car with it on a stand or block of wood and measure what you need, you could even try lock to lock like that and see what works best
just a thought
Rich _________________
Posted: Mon Aug 17, 2009 8:39 am Post subject: |
| You should also think about putting an IROC/WS6 steering box if you haven't got one already. The 245 cars had different stops than the 215 cars to prevent the front tires from rubbing. |
Posted: Mon Aug 17, 2009 1:53 pm Post subject: |
I actually need a new steering box ASAP as mine is leaking. I'm actively looking for one. As well as an adjustable panhard bar and 2" wheels adapters _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Aug 17, 2009 1:56 pm Post subject: |
Get a seat kit. _________________ A redline a day keeps the carbon away! |
Posted: Mon Aug 17, 2009 2:47 pm Post subject: |
I also want the quick ratio box, better for AutoX. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Aug 17, 2009 4:45 pm Post subject: |
Wow, just wow. Two Les Schwab locations I called have never heard of Nitto tires. Has anyone used DiscountTires2Go.com? I found the tire I need for $129 a piece whereas Tire Factory wanted $225 each and Discount Tire wanted $164 each. Before anyone says anything, Tirerack.com doesn't carry Nitto tires. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Aug 17, 2009 8:09 pm Post subject: |
| Why Nitto's? Worried about matching the set? On the dyno cruise Tony was just ahead of me, and I saw him get squirrelly in a couple of corners that I took at the same speed just fine. He runs (IIRC) Nitto 555s, while I had cheapo Kumhos. |
Posted: Mon Aug 17, 2009 8:30 pm Post subject: |
| aaron_sK wrote: | | Why Nitto's? Worried about matching the set? On the dyno cruise Tony was just ahead of me, and I saw him get squirrelly in a couple of corners that I took at the same speed just fine. He runs (IIRC) Nitto 555s, while I had cheapo Kumhos. |
Are you talking about the crosslace wheels he got from me? If so, those are not the 555s (which I've heard good things about the 555II's), those are the 450's which are a inexpenaive (comparatively) summer tire. I think I might've paid 500 for the whole set?
Not only that, it's Tony. You sure he wasn't trying to get squirely? Sorry Gambino!  _________________
