flea Member
Posted: Wed Jul 22, 2009 11:15 am Post subject: Wipers |
| I keep blowing my windshield wiper fuse. It blows immedietly when i turn them on so my question is, is there anything else on that fuse that could be causing this or is it pretty well narrowed down to the wipers. It must be a short in the wireing or the motor or is there another ACC to look at |
Posted: Wed Jul 22, 2009 4:35 pm Post subject: |
| Unplug the motor then see if it blows the fuse. |
flea Member
Posted: Wed Jul 22, 2009 6:35 pm Post subject: |
| It still pops the fuse. Is there anything else on that fuse? everything else seems to work but I could be missing something. |
Posted: Wed Jul 22, 2009 7:47 pm Post subject: |
| Looking at the wiring diagram, it appears it comes straight off the fuse then heads up the column to the wiper switch. From there it goes to the motor, then to the washer. So if unplugging the motor didnt stop it, then its most likely up the column somewhere.. or the switch. I think it has a plug in above your feet at the base of the column. Try unplugging there and see what happens. |
