		| Author | Message |
		| fiveoformula Member
 1988  Pontiac  Formula
				|  Posted: Wed Jul 15, 2009 8:54 pm    Post subject: Tuning stuff |   |
				| My moates stuff is on the way! Went with the burn2, 4 blank 512 chips and the cabl1.  Im stoked! Expecting it all to be here monday sometime. Now I need to find someone with a soldering iron, *cough* Skyler, to help me put in my adapter.
 Tips for Newbie tuners?
 '88 FORMULA
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Wed Jul 15, 2009 9:01 pm    Post subject: |   |
				| Don't know how it relates to TBI stuff, but the two biggest things I did were fixing all the temp controlled stuff (160* t-stat) and zeroing all but the main timing table, and working from there. |  |
		| Back to top |  |
		| fiveoformula Member
				|  Posted: Wed Jul 15, 2009 9:06 pm    Post subject: |   |
				| I am running a 180* stat. and I have my single fan on a relay with a manual switch. What do you mean by "zeroing" exactly?
		| Back to top |  |
				|  Posted: Wed Jul 15, 2009 11:00 pm    Post subject: |   |
				| Good luck getting a 512 chip to work. If you find out, let me know. Never could get those things to work. Only The atmel 256 chips.
 Other than that, lots of tuning to be had. Get an O2 bung, lots of beer, and a bribe to a certain crewbie and we can get you nailed.
		| Back to top |  |
		| fiveoformula Member
				|  Posted: Thu Jul 16, 2009 12:26 am    Post subject: |   |
				| Lol Id be happy to support the beverage if a couple of you guys want to show me the ropes with this stuff.
 Whats up with the 512 chips? As for the bung, I've got a wideband in there already if thats what it for?
		| Back to top |  |
				|  Posted: Thu Jul 16, 2009 6:54 am    Post subject: |   |
				| Oh yeah forgot you had the WB. Perfect. _________________
		| Back to top |  |
		| Al Hasse Member
 1992  Chevrolet  Camaro RS
				|  Posted: Thu Jul 16, 2009 7:26 am    Post subject: |   |
				|  	  | fiveoformula wrote: |  	  | Lol Id be happy to support the beverage if a couple of you guys want to show me the ropes with this stuff.
 I think it's an addressing thing.  It's on Moates' site where to set the beginning address (in the section where you order chips and stuff IIRC).  I think I've got one to work, but I need to go back and figure out what I did
		| Back to top |  |
		| fiveoformula Member
				|  Posted: Thu Jul 16, 2009 8:53 pm    Post subject: |   |
				|  	  | Al Hasse wrote: |  	  |  	  | fiveoformula wrote: |  	  | Lol Id be happy to support the beverage if a couple of you guys want to show me the ropes with this stuff.
 That'd be good. lol I wouldn't have bought them if I knew there were problems with them.
		| Back to top |  |
		| Boostd1 12sec Club
				|  Posted: Fri Jul 17, 2009 9:03 pm    Post subject: |   |
				| Tip #1
 NEVER tune around a mechanical problem...
 Have fun tuning! I'm just a phonecall away...
 2008 Saturn Astra XR | Sold
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Fri Jul 17, 2009 10:48 pm    Post subject: |   |
				|  	  | Boostd1 wrote: |  	  | Tip #1
 Hey now, do you know how much tuning it takes to fix a spotty throttle sensor? A LOT.
		| Back to top |  |
		| fiveoformula Member
				|  Posted: Sat Jul 18, 2009 1:00 am    Post subject: |   |
				| I thought it needed tuning before, it ran really crappy when it was cold then just less crappy once warmed up... Then dyno showed me the 16:1 AFR at wide-open!  |  |
		| Back to top |  |
		| iansane Member
 1991  Pontiac  Trans Am
				|  Posted: Sat Jul 18, 2009 7:28 am    Post subject: |   |
				|  	  | fiveoformula wrote: |  	  | I thought it needed tuning before, it ran really crappy when it was cold then just less crappy once warmed up... Then dyno showed me the 16:1 AFR at wide-open!  |
  When I first dyno'd the bird I pegged it 10:1. I'm sure it was richer, just didn't show. |  |
		| Back to top |  |
		| fiveoformula Member
				|  Posted: Sat Jul 18, 2009 12:30 pm    Post subject: |   |
				| Thats pretty much what my WB is showing now. lol I think theres some room for improvement.  |  |
		| Back to top |  |
		| DBL_TKE Member
 1991  Chevrolet  Camaro Z/28
				|  Posted: Sat Jul 18, 2009 1:55 pm    Post subject: |   |
				|  	  | iansane wrote: |  	  |  	  | fiveoformula wrote: |  	  | I thought it needed tuning before, it ran really crappy when it was cold then just less crappy once warmed up... Then dyno showed me the 16:1 AFR at wide-open!  |
 I had the same issue, I'll be fixing that soon
		| Back to top |  |
		| Mangus Member
 1989  Pontiac  Trans Am
				|  Posted: Sun Jul 19, 2009 3:56 pm    Post subject: |   |
				|  	  | DBL_TKE wrote: |  	  |  	  | iansane wrote: |  	  |  	  | fiveoformula wrote: |  	  | I thought it needed tuning before, it ran really crappy when it was cold then just less crappy once warmed up... Then dyno showed me the 16:1 AFR at wide-open!  |
 As did I (10.8 or something, I think). It's better now (in the 12.x:1 range ), but still not perfect. I suppose that goes to show, even those of us who do alot with the tuning thing don't have their own stuff tuned perfectly.
		| Back to top |  |
		| Boostd1 12sec Club
				|  Posted: Sun Jul 19, 2009 5:54 pm    Post subject: |   |
				| I think Derek's tune will be spot on.
 Wideband FTW
		| Back to top |  |
		| Dewey316 The Lama
 1990  Chevrolet  Camaro RS
				|  Posted: Sun Jul 19, 2009 6:06 pm    Post subject: |   |
				| even with a WB, getting the AE tuned right is the hardest part of tuning TBI. |  |
		| Back to top |  |
		| Boostd1 12sec Club
				|  Posted: Sun Jul 19, 2009 6:08 pm    Post subject: |   |
				|  	  | Dewey316 wrote: |  	  | even with a WB, getting the AE tuned right is the hardest part of tuning TBI. |
 Acceleration enrichment would probably be the hardest part...its the hardest part of tuning on my car as well. (PE)
		| Back to top |  |
		| fiveoformula Member
				|  Posted: Tue Jul 21, 2009 1:23 am    Post subject: |   |
				| Well I feel like a dork for saying this but I tried to hook up my ALDU1 to do some datalogging, and It's making the connection to my computer but it isn't connecting to tunerpro or WinALDL for that matter... This link might explain why...
 http://www.tunerpro.net/FAQALDL.htm
 But I don't really know what to do...
		| Back to top |  |
		| fiveoformula Member
				|  Posted: Tue Jul 21, 2009 5:09 pm    Post subject: |   |
				| Anyone know how to make this connect? |  |
		| Back to top |  |
