fiveoformula Member
Posted: Wed Jul 15, 2009 8:54 pm Post subject: Tuning stuff |
My moates stuff is on the way! Went with the burn2, 4 blank 512 chips and the cabl1. Im stoked! Expecting it all to be here monday sometime. Now I need to find someone with a soldering iron, *cough* Skyler, to help me put in my adapter.
Tips for Newbie tuners? _________________
'88 FORMULA |
Posted: Wed Jul 15, 2009 9:01 pm Post subject: |
| Don't know how it relates to TBI stuff, but the two biggest things I did were fixing all the temp controlled stuff (160* t-stat) and zeroing all but the main timing table, and working from there. |
fiveoformula Member
Posted: Wed Jul 15, 2009 9:06 pm Post subject: |
I am running a 180* stat. and I have my single fan on a relay with a manual switch.
What do you mean by "zeroing" exactly? |
Posted: Wed Jul 15, 2009 11:00 pm Post subject: |
Good luck getting a 512 chip to work. If you find out, let me know. Never could get those things to work. Only The atmel 256 chips.
Other than that, lots of tuning to be had. Get an O2 bung, lots of beer, and a bribe to a certain crewbie and we can get you nailed. _________________ A redline a day keeps the carbon away! |
fiveoformula Member
Posted: Thu Jul 16, 2009 12:26 am Post subject: |
Lol Id be happy to support the beverage if a couple of you guys want to show me the ropes with this stuff.
Whats up with the 512 chips? As for the bung, I've got a wideband in there already if thats what it for? |
Posted: Thu Jul 16, 2009 6:54 am Post subject: |
Oh yeah forgot you had the WB. Perfect. _________________ A redline a day keeps the carbon away! |
Posted: Thu Jul 16, 2009 7:26 am Post subject: |
| fiveoformula wrote: | Lol Id be happy to support the beverage if a couple of you guys want to show me the ropes with this stuff.
I think it's an addressing thing. It's on Moates' site where to set the beginning address (in the section where you order chips and stuff IIRC). I think I've got one to work, but I need to go back and figure out what I did  _________________ 92 Camaro
fiveoformula Member
Posted: Thu Jul 16, 2009 8:53 pm Post subject: |
| Al Hasse wrote: | | fiveoformula wrote: | Lol Id be happy to support the beverage if a couple of you guys want to show me the ropes with this stuff.
I think it's an addressing thing. It's on Moates' site where to set the beginning address (in the section where you order chips and stuff IIRC). I think I've got one to work, but I need to go back and figure out what I did  |
That'd be good. lol I wouldn't have bought them if I knew there were problems with them. |
Boostd1 12sec Club
Joined: 28 Oct 2008 Posts: 437 Location: Thornton, Colorado
Posted: Fri Jul 17, 2009 9:03 pm Post subject: |
Tip #1
NEVER tune around a mechanical problem...
Have fun tuning! I'm just a phonecall away... _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
2008 Saturn Astra XR | Sold
2007 Infiniti G35x | Current DD |
Posted: Fri Jul 17, 2009 10:48 pm Post subject: |
| Boostd1 wrote: | Tip #1
NEVER tune around a mechanical problem... |
Hey now, do you know how much tuning it takes to fix a spotty throttle sensor? A LOT.
fiveoformula Member
Posted: Sat Jul 18, 2009 1:00 am Post subject: |
I thought it needed tuning before, it ran really crappy when it was cold then just less crappy once warmed up... Then dyno showed me the 16:1 AFR at wide-open!  |
Posted: Sat Jul 18, 2009 7:28 am Post subject: |
| fiveoformula wrote: | I thought it needed tuning before, it ran really crappy when it was cold then just less crappy once warmed up... Then dyno showed me the 16:1 AFR at wide-open!  |
When I first dyno'd the bird I pegged it 10:1. I'm sure it was richer, just didn't show. |
fiveoformula Member
Posted: Sat Jul 18, 2009 12:30 pm Post subject: |
Thats pretty much what my WB is showing now. lol I think theres some room for improvement.  |
Posted: Sat Jul 18, 2009 1:55 pm Post subject: |
| iansane wrote: | | fiveoformula wrote: | I thought it needed tuning before, it ran really crappy when it was cold then just less crappy once warmed up... Then dyno showed me the 16:1 AFR at wide-open!  |
I had the same issue, I'll be fixing that soon  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Mangus Member
Joined: 10 Jan 2004 Posts: 254 Location: @computer in garage (Bothell)
1989 Pontiac Trans Am
Posted: Sun Jul 19, 2009 3:56 pm Post subject: |
| DBL_TKE wrote: | | iansane wrote: | | fiveoformula wrote: | I thought it needed tuning before, it ran really crappy when it was cold then just less crappy once warmed up... Then dyno showed me the 16:1 AFR at wide-open!  |
I had the same issue, I'll be fixing that soon  |
As did I (10.8 or something, I think). It's better now (in the 12.x:1 range ), but still not perfect. I suppose that goes to show, even those of us who do alot with the tuning thing don't have their own stuff tuned perfectly. |
Boostd1 12sec Club
Posted: Sun Jul 19, 2009 5:54 pm Post subject: |
I think Derek's tune will be spot on.
Wideband FTW  _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
Posted: Sun Jul 19, 2009 6:06 pm Post subject: |
| even with a WB, getting the AE tuned right is the hardest part of tuning TBI. |
Boostd1 12sec Club
Posted: Sun Jul 19, 2009 6:08 pm Post subject: |
| Dewey316 wrote: | | even with a WB, getting the AE tuned right is the hardest part of tuning TBI. |
Acceleration enrichment would probably be the hardest part...its the hardest part of tuning on my car as well. (PE) _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
fiveoformula Member
Posted: Tue Jul 21, 2009 1:23 am Post subject: |
Well I feel like a dork for saying this but I tried to hook up my ALDU1 to do some datalogging, and It's making the connection to my computer but it isn't connecting to tunerpro or WinALDL for that matter...
This link might explain why...
http://www.tunerpro.net/FAQALDL.htm
But I don't really know what to do... |
fiveoformula Member
Posted: Tue Jul 21, 2009 5:09 pm Post subject: |
| Anyone know how to make this connect? |
