Posted: Wed Jul 08, 2009 2:09 pm Post subject: carburetor's and cornering |
Can anyone give me a pointer on getting a carburetor to take hard corners well? Last time I took my car out on a corner it bogged a bit and acted like it had no power. I assume that I had a jet uncover but is there anythinge else to look for? I have side float bowls on a mechanical secondary 4150 DP with a single PV setup. _________________ E30
Posted: Wed Jul 08, 2009 2:44 pm Post subject: |
Get rid of the side hung float bowls and you're golden.
Make sure your float level is set properly, and make sure you have more than 1/4 tank of gas! _________________ A redline a day keeps the carbon away! |
Posted: Sun Jul 12, 2009 9:50 am Post subject: |
| Twilightoptics wrote: | Get rid of the side hung float bowls and you're golden.
Make sure your float level is set properly, |
Posted: Sun Jul 12, 2009 6:34 pm Post subject: |
don't worry Travis. With a big-block, you won't be able to go around corners anyway.  |
Posted: Mon Jul 13, 2009 7:07 am Post subject: |
| Not with traction anyway..... |
