BigDaddyVu 12sec Club
Posted: Sun Jun 07, 2009 5:49 pm Post subject: My turbo pics |
Carnage from my 350 4 bolt
Pics of my turbo mock up.
oil return from the turbo
sending unit tee'd for oiling the turbo.
Posted: Sun Jun 07, 2009 5:54 pm Post subject: |
Tearing apart my valve train.
izcain 9sec Club
Posted: Sun Jun 07, 2009 6:38 pm Post subject: |
So what have you determined was the cause of the damage?
What are the plans for the new engine? _________________
9.17 @ 148 |
Posted: Sun Jun 07, 2009 8:03 pm Post subject: |
fuel pump lagged out on the top end. The walbro wasn't rated for my fuel demands _________________
Posted: Sun Jun 07, 2009 8:06 pm Post subject: |
yeah, looks like not only did it break the piston, but it got effing hot too.
Did you hear it knocking, or was it just one big pre-detination that took out the piston? |
Posted: Sun Jun 07, 2009 8:11 pm Post subject: |
with the 400 replaced all the bearings and leave the topend alone. install i high volume high output oil pump. looking at a new aeromotive or BG fuel pump. at my highest boost i need a fuel pump 4 times the walbro pump. _________________
Posted: Sun Jun 07, 2009 8:18 pm Post subject: |
detonation killed just that No. 1 piston the rest are in very good shape the heads are in good shape too for the exception of molten piston splatter other wise rebuildable the cylender wall is toasted beings it is already at .060 over its not worth my time and money to rebuild it. but it did make a awsome firery pass and beat the other guy while doing it(12.84sec. 1/4mile). with this poorman build i am goning to run at 7 psi of boost instead of 14 psi. _________________
Posted: Sun Jun 07, 2009 8:21 pm Post subject: |
look how ugly wide this is.
Posted: Mon Jun 08, 2009 6:32 am Post subject: |
If the rest are fine sleeve the block and go for it. _________________ A redline a day keeps the carbon away! |
d00012 Member
Posted: Mon Jun 08, 2009 7:50 am Post subject: |
How does that fit?
Are you hogging all the secrets to quantum mechanics?
Just looks so big on the outside of the car... |
Posted: Mon Jun 08, 2009 9:04 am Post subject: |
| d00012 wrote: | How does that fit?
With the battery and coolant tank relocated you actually have a surprising amount of room in front of the fenders.
BTW, any setup that badass should totally have "MASTER POWER" stamped on it.  |
Posted: Mon Jun 08, 2009 8:17 pm Post subject: |
I should keep the block and rebuild it later its a 4 bolt main complete with arp studs, nuts, and bolts. Since i can't use the 2.02 heads on my 400sbc i am going to have the heads checked out and i am going to install them in my T/A with the 1.6 roller rockers. I had the heads rebuilt before i detonated it at the track. _________________
Posted: Mon Jun 08, 2009 8:21 pm Post subject: |
Posted: Mon Jun 08, 2009 9:28 pm Post subject: |
That last pic makes me want to play mario brothers!  |
Posted: Mon Jun 08, 2009 10:17 pm Post subject: |
No turtles!!! _________________
