Posted: Thu Jun 04, 2009 9:19 am Post subject: Headlight problem - '87 T/A |
Here's the car I got:
http://cascadecrew.org/phpBB2/viewtopic.php?p=65870
The problem is that the headlights raise up just fine, but I don't get any light. Could just be the bulbs, but high and low beams both don't work. According to the previous owner it just happened one day. No bad fuses, could it be the headlight switch? Or a fusible link somewhere? _________________ 84 Camaro Z28 - LS1/T56
Posted: Thu Jun 04, 2009 9:35 am Post subject: |
Sounds like maybe the headlight switch. There is a thermal breaker in the switch that could have failed open and not reset. If memory serves, that is the only circuit protection for the headlights. _________________ 92 Camaro
