HONDASLAYER Member
Posted: Wed Apr 08, 2009 2:50 pm Post subject: Gotta carb question... |
Ok so i want to eliminate my computer controled carb. but i have an electric choke. my question is... Is the electric choke controled by the computer and if so does that mean that if a want a non computer carb that i would have to install a manual choke and carb?  _________________
Posted: Wed Apr 08, 2009 3:06 pm Post subject: |
| If you ditch the computer controlled car the computer will become useless. You will also have to get a non computer controlled distributor. The choke shouldn't pose any problem sense many carbs come with an electric choke. |
HONDASLAYER Member
Posted: Wed Apr 08, 2009 3:18 pm Post subject: |
| rjmcgee wrote: | | If you ditch the computer controlled car the computer will become useless. You will also have to get a non computer controlled distributor. The choke shouldn't pose any problem sense many carbs come with an electric choke. |
Ya i'm going to get the distributor too. I'm just checking to see if the electric choke is conrtolled by the computer or not. If its not then how does it know when to engage and dis-engage? _________________
Posted: Wed Apr 08, 2009 3:35 pm Post subject: |
It gets a 12v signal when you turn the key on. From there it runs the power through the thermal choke spring inside. The spring grows rotating the choke lever as it heats up. _________________ A redline a day keeps the carbon away! |
HONDASLAYER Member
Posted: Wed Apr 08, 2009 3:44 pm Post subject: |
| Twilightoptics wrote: | | It gets a 12v signal when you turn the key on. From there it runs the power through the thermal choke spring inside. The spring grows rotating the choke lever as it heats up. |
thanks paul. _________________
