chains of command
'92 camaro boss
PostPosted: Sun Mar 29, 2009 6:55 pm    Post subject: chains of command Reply with quote
ok, so i've had a bad experience with the fuel pump once before.
i ended up driving around a couple weeks ago and i could not hold a steady rpm rate, then as i putted into a gas station, it died all together, so i went to start it, and it will run at idle and if you give it any gas at all it will try to rev up and die, today i pulled the fuel pump, tried one we have sitting here, then went and bought a new one and put it in, same problem.. i'm about ready to just sell the damn car since i drive it litterally a month at a time. before it breaks down.
basically before i hand over hard earned dollars to a shop what else should i check? fuel pressure regulater? i changed the fuel filter already...
thanks in advance for any help.
PostPosted: Sun Mar 29, 2009 6:57 pm    Post subject: Reply with quote
Check the small rubber line the connects the fuel pump to the output tube. A small crack or hole in that, and you won't build any pressure at all.
--John
kurfbird
PostPosted: Mon Mar 30, 2009 9:48 pm    Post subject: possible timming chain Reply with quote
Is it running rich and no power could be your timming chain
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
